Ported lower intake.....
#86
ill tell you first hand what happens, im not a tester i did my own. Basically what happens it boost builds alot faster, i can pretty much punch it and watch my boost go straight to the max. You might see about 1 PSI more at the top of each gear. Expect maybe 10-15WHP from this mod at most. The better gain is how hard the boost hits and how instant it is.
#87
#88
#93
I don't get that. With a particular pulley, you get a certain flow out of the supercharger. That flow coupled with a stock IM will give you a certain psi (restriction). With a ported IM, there is less restriction and also lower IAT2's so unless you also pullied down, the psi should actually drop.
porting an intake manifold will actually raise IAT temps, when you port the intake manifold you decrease the amount of time the air spends moving through the laminova cores spends being cooled, you also increase the amount of air going past the cores. Also you should see an increase in boost because the boost pressure is measured after the laminova cores, removing the restriction will allow more boost to build after the cores.
#96
C'mon lsj, for those of us who really need it, when are you going to start selling them? Plus I want to see what you come up with the supercharged cams. (tvs)
