Ported lower intake.....
#103
#110
#112
no wrong
porting an intake manifold will actually raise IAT temps, when you port the intake manifold you decrease the amount of time the air spends moving through the laminova cores spends being cooled, you also increase the amount of air going past the cores. Also you should see an increase in boost because the boost pressure is measured after the laminova cores, removing the restriction will allow more boost to build after the cores.
#113
#116
don't keep it. many better options out there + gm running into the ground while the top 10 execs are pulling in over a billion dollars in bonuses every year EVEN THOUGH THE COMPANY IS RUNNING INTO THE GROUND
screw a bunch of chevy
#119
#122
It has been done on a m62, the gains were meger 5 whp, as far as cooling goes the gains were much much better about a 24* drop in iat's.
#123
bout what i expected. im going to do dyno steps with the single pass im when i get the head on to see what kind of gains they do.
#125
i have a hunch this IM will make an extra 15 whp on a ported+rebuilt head.
