porting my s/c RIGHT NOW AS WE SPEAK
#251
#252
An you just FAILED HUGE.
The air would not move through the system without a pressure drop. Simple physics, fluids what ever you want to call it.
#253
You have yet to find anything ive said that is not correct at this thread.
#254
OH no I just found a big one and let you know above
#255
The ocean waves are also another form of a fluid moving yet they have to do with gravity. PSI can be any fluid, not just air.
#256
Im not skewing anything. You said his statement was wrong, and it is not it is fully correct, for the application we are talking about
#257
barometric pressure and psi are different.
#258
Hence why CFD (computational fluid dynamics) is used in wind tunnel simulation.
Holy fail!
I'm pretty sure psi is a measurement of pressure.
#259
dude your a moron, read about pressure drop in a system, i dont care what system and you will see. Its all the same, just piping, intercooler. I dont care, you need a little bit of pressure drop for a system to work. You just dont know how to be wrong, except you have been all the time
#261
#262
fail man... wow and you took an undergrad course?
#264
#265
Unfortunatley it will be an hour and i leave at 5:00 so i have about 30 minutes for some failing to go on via my part.
I may check before bed.
#266
wouldnt want to keep you up to late, you can't even seem to comprehend with a full nights sleep
#267
#270
in other words
take a cup,
fill it half way with water,
fill other half with milk
notice the differences in density/pressure and how it moves to equalize?
That is NOT the same as shooting water through a hose and is completely off topic.
#272
"...we have a high pressure system moving in....."
"...when that low pressure system meets the front from the high pressure system...."
"...high winds due to PRESSURE DIFFERENTIAL....tornado...hurricane..."
BTW - florida is at 14.7psi absolute - just so you know....
#273
Holy Mary Mother of God.....
#274
