porting my s/c RIGHT NOW AS WE SPEAK
#176
What dimensions?... Pick any one of the 16G's (small, big, ported) and compare it to the GT35R.
There is no 2 ways around it, the GT flows more.
#177
#178
#179
im trying to avoid bringing alot of equations in to the mix, because CFM will vary greatly on too many other features (which i purposely have left out of this convo). We could bring in altitude differences, temperature, dimensions, and certain bottlenecks which could fit your argument and then i would have to knock them all down another 10 pages from now. Arguing with 3 people who just argue for the sake of me being an ******* is not going to make physics change.
All of my arguments are based off identical variables that compare psi x dimensions x cfm. Strictly that.
edit:
Also this explains why i speak in terms of PSI.
When you know the PSI you know the restrictions of CFM. Knowing a problem will help you eliminate it.
In other words, when my piston is being shot through my block, i dont look at why my rods look so great. That doesnt identify the problem. I look at what could have caused this error.
PSI to me is an error BUT its a good baseline to go off of to identify how to free this restriction up to gain the proper amounts of CFM short of increasing dimensions.
I hope this clears THAT up.
edit:
#180
Rent me! per hour
im not contradicting anything. you're looking for a way out of the hole you dug.
how about you call up stegmeier in st charles missouri and explain to them that porting does nothing.
go ahead. i'll be waiting for the answer.
as psi goes up. so does cfm. untill you hit the end of the compressor map. then it's anyones guess. you are messing with a grey area that many have not delt with.
no matter how big an inlet is. it will only move so much air that the outlet will allow.
making an boosted engine more efficient will require less "psi" to make the same power, usually it makes more.
#181
Im talking about OUR car.... not other's.
The intake was never changed and IS the bottleneck. If that intake manifold did NOT increase PSI then you should have Stegmier (sp?) call up Eaton engineers and tell them what is up. Since obviously the engineers that designed it were sleeping like the GM techs.
The rest i agree with and have said prior.
#185
#186
Why are you dragging our intake into this?... Yes it's a restriction, but that's a whole different discussion.
Right now, we are comparing a common closed system to itself, when simply changing the compressor. Meaning the same piping, intercooler, intake, motor (in it's entire) and exhaust system... with a different compressor.
#187
Do you even read the stuff you post?
Identical Engines, piping, Intercooler, atmospheric conditions, etc, etc. The ONLY thing that we change is replacing the supercharger / turbo with a larger unit and run it at the same PSI as the orginal unit. So....with the larger compressor running at the same PSI as the original compressor, what happens to the CFM of the system? And more importantly, WHY?
#188
ok kids,
time for 3rd grade science.
Children lets do an experiment. Yes, you too can follow along at home and do this. We are going to explain to all these "math and engineering" whiz-kids what CFM, PSI, and why porting doesnt exist.
materials needed:
balloon
needle
scissors
ok before you blow the balloon up.... poke a needle sized hole in to that balloon. Dont blow it up BEFORE poking it (i have to explain this since 11+ pages and people cant grasp it)
now. Blow that balloon up and watch it leak air ever so slowly.
the air from your lungs to the balloon is like the eaton supercharger (lungs) in to the intake manifold (balloon). The air that is leaking (needle pin hole) is the proper CFM going to the cylinder.
Notice how little CFM or air comes out. Notice the PSI created from blowing the balloon up (intake)
ooooooo
Now, lets free that intake up and cut a hole where the needle hole is about the size of quarter. Again, blow up the balloon.
Thus creating more CFM (out of the bigger hole) and less PSI (balloon size)
now...
if you can afford another balloon. Lets try what everyone else was talking about.....
Open your mouth as wide as you can and blow that balloon up. Whats this?
can it be?
yup im sure of it. The same amount of PSI and CFM is flowing through the balloon (intake)
Now children, i am done gracing this thread with my intelligence and ridiculing you all on what CFM vs PSI vs Dimensions really means.
special thanks to my after-lunch smoke to come up with this little project
materials needed:
balloon
needle
scissors
ooooooo
now...
can it be?
#190
#191
#192
Also, this is what happens when you push too much air in to that "balloon" that it can not handle.
https://www.cobaltss.net/forums/show...astic+manifold
Its pretty fricken accurate.
#193
Your talking about pre-cooler pressure build up.... not post cooler (engine side, map side, boost gauge side).
And besides that, your experiment does not explain your standing on why a ported blower doesn't work, all it proves is that an intercooler causes pressure drop, which we all know.
#194
that is bull.
Blow that balloon up and put it in the freezer. THAT is intercooler pressure drop when it shrinks to the size of a pea"
Last edited by rrutter81; 07-08-2008 at 02:09 PM. Reason: took out the name calling
#195
And putting it in the freezer sould not mimic intercooler pressure drop, that statement would make you the idiot(i was trying to avoid the name calling, but you seem ok with it)
that is not why there is pressure drop through an intercooler.
You need to learn more about the system before you try and preach buddy
#196
i give you real-world examples of what is happening to our cobalts with the experiment. it is pretty damn accurate.
apologies for the name calling. that was out of line.
#197
its not accurate and then your intercooler statement was even further off as well. Putting a balloon in a frezzer when its full of air and saying it will shrink is like pressure drop through and intercooler is an extremely wrong statement
#198
oh im sorry, maybe that whole bit about how molecules expand under heat was just b.s.
/sarcasm
read more please
#199
Rutter,
In your experiment, you are assuming that the engine, piping, IC, etc etc are already at their maximum CFM capacity - which they are not.
Putting the balloon in the freezer does give you PSI drop - but it is due to the decrease in air temp causing the density to increase which results in a volume decrease.
#200
Rutter,
did you create 1 PSI?
then yes, it is at maximum. Please try again.
NEXT!
