possable new intake manifold for lsj
#101
When is zooomer gonna step in? i agree that most ppl probly wont buy this for the reasons of price and ease of install. However there are plenty that will definately buy this. Id love to continue making piwer on my m62 and if its around 600 i would definately get this. Especially if the oil filter is not that bad like mr b is saying
#102
#103
wtf do you mean a different story your making this out like its going to take some special machining processs it isent hard all you need is a saws all to cut it off then you can weld your -10 bungs to the block and plug the bypass hole and done how do you think gm did it and not to mention they say to remove the housing with a saws all and as for manifold fitment id bet your way off the mark you have to remember for this to work for 95% of the people out there it has to be plug and play or they wont buy it
It's not rocket science, but I would do such removal procedure only on a bare engine casing so you can clean all the metal shavings from the oil channels...
And most people here will find that really a different story than simply screwing an oil adapter plate in the filter housing.
I really hope this thing works and can be fitted with some simple engine mods, but seeing the dimensions in relation to the intake flange position, most likely something more is needed.
We can discuss this forever, but it's time for ZZP to enlighten us.
