possable new intake manifold for lsj
Old 12-23-2012, 12:36 AM
  #101
When is zooomer gonna step in? i agree that most ppl probly wont buy this for the reasons of price and ease of install. However there are plenty that will definately buy this. Id love to continue making piwer on my m62 and if its around 600 i would definately get this. Especially if the oil filter is not that bad like mr b is saying
Old 12-23-2012, 08:17 AM
  #102
mrbelvedere's Avatar
Originally Posted by Vander Nars
no one wants to have to remove an oil filter housing, zzp knows this and wouldnt put out an item that very few will buy if the engine has to be modded to fit.
indeed
although its not hard to do I doubt seriously that the oil filter housing will need to be removed this manifold will be plug and play
Old 12-23-2012, 09:17 AM
  #103
Speedytec's Avatar
Originally Posted by mrbelvedere
wtf do you mean a different story your making this out like its going to take some special machining processs it isent hard all you need is a saws all to cut it off then you can weld your -10 bungs to the block and plug the bypass hole and done how do you think gm did it and not to mention they say to remove the housing with a saws all and as for manifold fitment id bet your way off the mark you have to remember for this to work for 95% of the people out there it has to be plug and play or they wont buy it
It's not rocket science, but I would do such removal procedure only on a bare engine casing so you can clean all the metal shavings from the oil channels...
And most people here will find that really a different story than simply screwing an oil adapter plate in the filter housing.
I really hope this thing works and can be fitted with some simple engine mods, but seeing the dimensions in relation to the intake flange position, most likely something more is needed.
We can discuss this forever, but it's time for ZZP to enlighten us.
Old 12-23-2012, 10:48 AM
  #104
YelCal7's Avatar
From what I see all it does to flip the Supercharger to sideway. ZZP is not going to waste our time to do all that hassle for changing that oil filter location.
Old 12-23-2012, 04:07 PM
  #105
Im just interested now to see if theres a specific intake you must buy along with it due to relocation
Old 12-23-2012, 04:17 PM
  #106
IonNinja's Avatar
No way this cost under 1K
Old 12-23-2012, 06:07 PM
  #107
nhanson's Avatar
lol what?
ZZPs full IC kit for the 3800 is $1100 and that includes a LIM, heat exchanger, lines, gaskets, and bolts!
  #108
ThexGovenor's Avatar
What do you see as being the most expensive part that will push it over 1k?
Old 12-23-2012, 06:16 PM
  #109
574
574's Avatar
I bet you will have to buy a new intake
Old 12-23-2012, 06:34 PM
  #110
Tjolley's Avatar
im hoping they have a easy cuppler change or something..
Supercharged06SS
12-11-2022 04:47 PM
DarrenGC
12-24-2021 01:55 PM
06MetallicBalt
08-17-2021 03:40 PM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
Quick Reply: possable new intake manifold for lsj
