pulley puller. zzp and nates
It will work, but make sure you don't use the pulley bolted to the hub to remove it. You will need a removal plate which bolts to the hub to pull it off safely. I'm not saying that it definitely will, but it can very easily damage the pulley because it takes quite a bit of force to pull off the hub. If you need a removal plate I would be happy to make one for you!
Nate
Nate
