pulley size
pulley size
hey i was just wondering what size of pulley i can actually use with 60 lb injectors, 2.5 custom exhaust and aem intake?? and then later on get a heat exchanger if needed...also i'll be getting a custom tune with hp tuners...i was thinking of 2.7 inch would be fine but i want to be safe then sorry...
if your gonna use 60lb injectors might as well go with a 2.5" inch pulley, no sense of going with a 2.7 with the same mods accompanying a 2.5" you might wana get a bigger exhaust though.
With a 2.5 you will be overspining like a biotch, you will nuke your blower in time, also the amount of heat that creates will negate the torque you will gain, because going from a 2.7 to 2.5 is just going to be mostly torque, imo go with a 2.7, its right in the middle, and still produces good power, but also still produces much un-wanted heat.
