Pulleyboyz 2.8 GM stage 2 ring!!!!!!!!! OMG OMG
#127
Originally Posted by mjbroeker
Does anyone know the magnitutde of removing the supercharger and drilling the bits out? I am running out of options.
if you have the belt off, its just 4 bolts, some electricals and vacuum line and she lifts off, just make sure to put something to cover the intercooler while you work on the s.c and make sure nothing gets in the s/c or the IC
also be careful with the TB....
#131
#132
It makes me wonder how much the little mystery part cost us. Maybe thats why the kit prices went down no mystery parts.
By the way has anyone figured out a perfect plug and gap to run with the PB 2.8?
#133
Well I just ordered my pulley... waiting for my Stage 2 to come in.. And once I screw around with stock pulley.. I will put the other one on...
Question.. What plugs should I be running... Any definate anwers yet?
#137
I use stock plugs and no issues. I put the copper ones in and they seems to not run as good as the stock one so I put the stock ones back in and i am running fine.
#139
Well I just got mine tonight. It only took 3 days to ship the pulley. I did a one man install and it took about 30 minutes, I almost stripped the pulley loosener and i ended up having to use a vice grip and I had to squize as tight as i could. I totally recommend having another person with you!! After test driving it, it was like a whole new beast. Overall great pulley thanks pulley boyz.
#140
Well I finally got my Stage2 pulley off. My son came over last night and gave me a hand. Those blue bolts sure were tight. Used a rubber strap wrench to help hold the pulley still. If you look at the bit that came with the Stage2 kit it has a spiral to it. That spiral bit was made to torque things on with, it was never meant to be used for removal. What did you guys torque your bolts to? I torque the bolts that I purchased with the Pulley Boys pulley to 25 ft lbs
#141
Originally Posted by rhanes216213
Well if finally got my Stage2 pulley off. My son came over last night and gave me a hand. Those blue bolts sure were tight. Used a rubber strap wrench to help hold the pulley still. If you look at the bit that came with the Stage2 kit it has a spiral to it. That spiral bit was made to torque things on with, it was never meant to be used for removal. What did you guys torque your bolts to? I torque the bolts that I purchased with the Pulley Boys pulley to 25 ft lbs
#143
Has anyone else done any data logging with this pulley? My injectors are maxing out around 6800 rpms and the car is running a little on the lean side. My only other mod is a K&N intake
#144
CRC has a new product that does wonders for cleaning the maf's it evaps quick and works very well
#145
Originally Posted by SS_SC_Cobalt
Max_boost, make sure to clean the maf then take new readings
#146
1 Post
The MAF is clean, I just cleaned it not long ago.
#147
Between 3000-5500 RPM I see 12.8 -12.2 and near 7000 I see high 11's on the WEGO.
Runs a tad lean under 3/4 throttle up hills though. Nice at WOT.
#149
1 Post
Originally Posted by BACK2GM
just wondering if i order stage1, stage2 belt and 2.8 pulley what eles would i need to
complete the setup to have the dealer put in?
