Question
Old 03-02-2008, 10:52 PM
BlackSSNick's Avatar
Question
Anybody running 60# injectors smaller pulley and a tune only? no other mods. If so, what size pulley with 60#'s?
Old 03-02-2008, 10:59 PM
lsjwannabe's Avatar
i ran 2.5 and 60's for 7 months
Old 03-02-2008, 11:03 PM
any problems? what kind of numbers?
Old 03-02-2008, 11:07 PM
Greased's Avatar
what? w/o cooling mods?! does your engine like being fed a blow torch???
sorry im so skeptical but thats hard to believe you did that, must have had a very conservative tune
Old 03-02-2008, 11:09 PM
lsjwannabe's Avatar
tune was 23* timing and a 12.4 afr on 93 pump gas
the car was fine, i don't beat on the car much. It did see the track once that year for like 7 runs and was fine.
never dyno'd back then
12.4 afr?
Old 03-02-2008, 11:10 PM
lsjwannabe's Avatar
yeah
Old 03-02-2008, 11:14 PM
what is a 12.4 afr? I prolly know this, but can;t figure out the acronym.
air fuel ratio, nevermind
Last edited by BlackSSNick; 03-02-2008 at 11:14 PM. Reason: figured the acronym out
Old 03-02-2008, 11:15 PM
lsjwannabe's Avatar
bingo
thats rich though? you could get more power out of it if you leaned it out couldn;t you?
Old 03-02-2008, 11:17 PM
lsjwannabe's Avatar
haha lower the number the more rich. That is pretty damn lean for a boosted car
you could not pinch much more out of it with out supporting mods
ralliartist's Avatar
lol, 12.4 afr is a pretty damn good afr. any leaner go boom! and any richer you probably would just lose power.
Old 03-02-2008, 11:18 PM
lsjwannabe's Avatar
11.5~11.8 is safe but good for power to, 12.4 is pushing it. you don't make anything after that
Old 03-02-2008, 11:21 PM
ok i was confused. I thought lower the number the leaner. when I dynoed my car is was running at 10 lol. pretty rich but it's factory stock tuned. I am gonna go aftermarket injectors, aftermarket pulley, and tune time tune I think. Any advice for a powerful tune but a safe don;t blow up my engine tune?
Old 03-02-2008, 11:25 PM
lsjwannabe's Avatar
the tuner should take care of it, 11.5 afr is fine and 16 * timing is cool to. matt knows what he is doing and will take care of you don't worry
Old 03-02-2008, 11:31 PM
did you go to tune time? and is it worth the drive from nazareth pa? (lehigh valley)
Old 03-02-2008, 11:32 PM
lsjwannabe's Avatar
no, i tune my car and others. i have heard good things about them though from many members.
no shop would ever tune like that lol
Old 03-02-2008, 11:33 PM
tune like what?
Old 03-02-2008, 11:37 PM
on the edge. that much timing and that lean was pretty crazy with no cooling mods.
I don't even run that lean and I have cooling mods.
Old 03-02-2008, 11:39 PM
ok, this is good info here because i'll probably be getting a tune this summer and I want to be slightly educated on this. Any other advice????
Old 03-02-2008, 11:42 PM
lsjwannabe's Avatar
how cold does it get around you? weather can mess with your afr and can make you run leaner in the cooler months
GET COOLING MODS! lol. Seriously, pick up a heat exchanger and you should be fine. It'll allow for some extra timing advance which will help out with power of course.
Old 03-02-2008, 11:43 PM
lsjwannabe's Avatar
also cools iat's, to recliam some power
Old 03-02-2008, 11:49 PM
alright i'll do the heat exchanger too, could i upgrade the whole intercooler system? Gets really cold, sometimes in the teens, but mainly stays in the 30's
Old 03-02-2008, 11:51 PM
lsjwannabe's Avatar
you can get a dual pass endplate for the intercooler.
Quick Reply: Question
