questions....
Well dude, if they won't work on your hydraulic issue for free then I assume your warranty is shot already, so unless I'm missing something you shouldn't be too concerned. If I were you I'd just buy a stage 2 kit from OTTP with a 2.8 or 2.9 pulley.... then you could pick up a heat exchanger for decently cheap in the bundle. They will provide you with a canned tune that'll work just fine.
the only reason that they wouldn't cover any of the work is because it is an aftermarket clutch (but it was on there when i bought the damn thing.... ) so as far as my motor goes and everything else it should be good
so i was looking for an exhaust manifold gasket and i found this one... will this work fine with the zzp mid length header and dp combo with 1.75 primaries to a 3in collector?
baltman51
07-09-2014 11:55 PM
JetBlackSS
05-28-2011 03:12 AM
