questions regarding LSJ build guide
Old 06-12-2007 | 04:25 PM
Z Speed's Avatar
I was reading through the LSJ build guide for reference when it comes time to do motor work..... Im curious is to why they reused the piston rings.... I was planning on doing a rebuild and wanted to get new rods and pistons then it came to thought that would I need to bore the block out or can i get away with just rehoning the block and using new rings. info from people that have rebuilt there motors would be helpful cause I would like to make this like a weekend project.... but if worst comes to worst I will get a new block and stuff.
one other question was what are some other options for rods for the LSJ. I seen j-body performance has them but I just wanted to see if there was other options out there. I remember reading about someones signature and it said they have crower rods. So I was curious if crower did actually come out with rods for our motors.
sorry if this is a repost but info to what im looking for IMO should be in a sticky somewhere on the forums for everyone wondering this same question.
Old 06-12-2007 | 05:14 PM
Area47's Avatar
Rent me! per hour
if the motor was never fired, you can reuse them
Old 06-12-2007 | 05:31 PM
Smarty Art's Avatar
If you use differnet rings your cylinder walls need to be honed. If you use the stock ones they don't.
Old 06-12-2007 | 05:32 PM
chevysalesman614's Avatar
if you're serious about building your motor i would look into pistons and rods (aftermarket) for the 2.2L or 2.4L ecotecs... i.e. a stroker. I'm sure there would be hiccups along the way, but at the end of the day, the added displacement, in conjunction with the beast LSJ head would be well worth it.
Old 06-13-2007 | 09:52 AM
Z Speed's Avatar
bump for more insight
Old 06-13-2007 | 07:46 PM
07cobaltss's Avatar
NEVER reuse piston rings. in taking them out using the piston ring remover you can and most likely will open the gap between the two ends of the ring and that can create problems. if your doing a complete build and you can afford it. spend the extra 30-50 bucks on new rings...
lol... guys your piston ring are constanly moving. they dont sit in one spot they twist around in the ring lands. so the wear shouldnt be constant on the rings. you will have more wear on the thrust side of the cylinder walls, but the rings shouldnt be out of round. PUT NEW RINGS IN. dont be cheap when it comes to a build. because you'll see it in the end.
Old 06-13-2007 | 08:07 PM
Smarty Art's Avatar
Takin right from the build book.
"While the stock pistons need to be replaced,
the stock rings are more than ready to handle
big power."
You have to transfer them to the same piston and in the same order.
Old 06-13-2007 | 08:57 PM
Area47's Avatar
Rent me! per hour
try this on for size.
say you have a motor, you just put pistons and rings in, fresh walls. never fired, never had the heads on, or head on. notice that said piston is in wrong.
what happens
you take the piston out, flip it around, and stick it back in.
does this require new rings?
ONLY if you mess them up.
Old 06-15-2007 | 10:19 AM
Z Speed's Avatar
thats what i thought. besides the fact that theres better rings out there besides the stockers
Old 06-15-2007 | 12:31 PM
ptrblkz24's Avatar
big power
Does it say in the build book they reused them?Cause by reading that,it sounds like to me,there just using stock rings.Meaning,they go to the dealer and buy brand new stock rings,not reuse them.
what happens
No you dont have to replace the rings,bacause you arent removing the rings from the piston.
Supercharged06SS
12-11-2022 05:47 PM
05-28-2022 04:47 AM
06MetallicBalt
08-17-2021 04:40 PM
brandon04
10-21-2015 08:04 AM
Trav3480
09-28-2015 03:46 PM
