Quick Exhaust Question!
Hey guys. I just need to know if this is a full exhaust system or am I missing something like any extra peices that have to be welded? Will all of this bolt right up? Also where do I get new gaskets? Thanks everyone!
1. GM Honed/Extruded Manifold.
2. ZZP Downpipe with CAT.
3. GMPP Cat-Back Sport Exhaust
4. GM Slant Cut Exhaust Tip.
5. New Gaskets
That should just about do it right?
5. New Gaskets
Originally Posted by HackAbuse
Get a real header, not just a ported stock manifold
So will all of those items bolt right up? Like the ZZP Downpipe w/CAT to the GM Manifold etc ?
Also where do I get new gaskets, Crate Engine Depot or something? Thanks all!
Originally Posted by CTCOBALTSSS
I want to avoid a true header because of the heat it gives off. I'm also trying to stay as GM as possible. I know there would be better gains but I want to avoid the heat. I'm in traffic a lot and that won't be cool.
Originally Posted by patathSS
Yeah it should bolt up just fine, just make sure you get the bolt in options. Also, you can probably get gaskets at your local parts counter.
