quick timing tensioner question
I have about 70000 on my lsj,..at start up I get a lil tap sound til my temp gets to about 100,..then it goes away,..car idles excellent,..no sound except at start up,..but under acceleration theres a chainy rattle sound,..but its been like this for months,..no performance issues,..no codes,,,just an annoying sound,...under idle nothing,..and only few secs of tap at start up,..you can hear it inside of car and if I have my dad drive by in my car I cannot hear it from outside,...what do you guys think
so I can just unscrew old one and then put new one in,,,i read all this horror about stuff going wrong,,,some say take valve cover off n zip tie gears,,,some say just remove old in with new
its all internet tribal wisdom. Put the new one in, after removing and throwing away the old one. no setting no bs. If you want to remove the rocker cover and all that go ahead an waste your time. Like Armclure said on another thread, its probably impossible to jump time changing the tensioner for the upgraded one.
I have a local shop that quoted me 192 for labor and parts,...I could do it myself for less than 50,...ill decide this morning,...it sounds too easy,..especially if u ziptie the gears and chain so it cant move
You only had to set them, with the old style tensioner.
no need to pull the vale cover.
You sure it's coming from the engine and not possibly the trans? Just thinkning out loud. The few tensioners I've seen go bad, "diesel" at idle
all new before and it was the intake side that jumped a tooth after removing tensioner i assure you nothing is mechanically wrong with engine. i would never replace a tensioner without verifying that the timing marks are lined up why be lazy and take the chance of valves saying hello to pistons??
mine jumped teeth when I did the plug and play. I should have rotated the engine by hand instead of bumping the starter. I bought a new chain, and the length matched up perfectly with the old one. The gears were fine. All the guides were fine. I think the chain may have jumped when I removed the old tensioner. I wanted to turn the final threads by hand when removing it to prevent it from popping out and possibly unsetting the chain, but I couldn't turn it by hand. I used a socket, and it popped out into the socket. This is probably what unset the chain and allowed the cam gear to move especially if the exhaust cam wasn't in a resting position.
If I had to do it again i would still probably just do a plug and play, but i would rotate the crank by hand with a wrench to make sure it didnt jump teeth before bumping the starter, and definitely keep a lot of axial force on the tensioner while it's being removed. I would suggest using an open ended wrench or box wrench so you can push on it and remove it slowly.
It ended up costing me $500 for a head gasket kit, new valves, seals, guides, and the head work.
