really bad clutch problems
This has been happening a lot lately almost like its getting worse. What happens is ill stage up to run the quarter ill put the clutch in and put the car in 1st. Light turns green and I take my foot off the clutch go. Second gear comes I put the clutch in n its almost hard as a rock and its grabbing point has changed and the car goes into second. Third gear comes I push the clutch in again very very hard way above normal hardness and try to go into gear but my clutch didn't engage and the car won't go into 3rd gear. So I have to pump the clutch n then it goes into 3rd gear. Depending on how I drive depends on which gear the clutch stops workin and I have to pump it while going down the quarter mile track. As far as the clutch grabbing it grabs all the gears n holds them well like no slipping. Also my brakes feel very weird like I have to pus them a lot further down to stop. My rotors n pads aren't in the best of condition but this also has been happening when they were brand new. What could b the problem. Any idea?
Yes it is the stock clutch. I just did that. I changed the brake fluid in the master cyl and bled the clutch until clean brake fluid came thru and it worked fine for about a week or 2 then it started happening again
