Rebel Auto Worxs Twin Screw tuning session and Video
Old 07-24-2007, 07:32 PM
  #76
chevysalesman614's Avatar
Originally Posted by lsjwannabe
16k sustained 18k max
thanks.
this one is 100cfm bigger, and more effecient.. i'm liking this over the turbo.. at least for my needs. i just wanna run high 12s off the bottle, and low 12s on it.
plus the driveability and low end torque of the ss s/c are why i bought it. i imagine the characteristics of the car would stay closer to stock if i went the twin screw route
Originally Posted by KillerBee
Finally someone who can actually do this **** you probably sell out real quick subscribed i want one
yup i think there is another vendor crying about this right now
Originally Posted by Kritter
Ok, so in the end, we can run this new blower without upgrading the internals and not worry about it, correct? Eventually I'll up the intenals regardless, but once I buy this, and the suspension/drive upgraes to hndle th new power, I'll be low for a bit on the money. Sorry to soundlike a puss, but the car is my daily driver a well as my toy, and I'm still paying on it, so hopefully you guys can understand my wanting to be sure of this.
you will probably have to spring for an upgraded clutch and axles.. plus drag radials would be a very good idea.
Last edited by chevysalesman614; 07-24-2007 at 07:32 PM. Reason: Automerged Doublepost
Old 07-24-2007, 07:36 PM
  #77
Kritter's Avatar
Originally Posted by chevysalesman614
thanks.
Yeah, hence the part about upgrading the suspension/drive part...no way in hell the stockers will hold up to this, but good to know the motor will.
Old 07-24-2007, 07:38 PM
  #78
Sales@rebelautoworxs's Avatar
Clutch For sure axles should be fine if your not a track goer with sticky tires it would get ugly.
Like i said excellent upgrade over stock blower and a blast to drive!
This car will run 12's.. with some tires
Old 07-24-2007, 07:41 PM
  #79
i guess i suck at reading.. i thought you phrased it like a question.
thats all i needed to hear.
BriDoc614@yahoo.com - write that down. i want to know when i can buy this.
Last edited by chevysalesman614; 07-24-2007 at 07:42 PM. Reason: Automerged Doublepost
  #80
lsjwannabe's Avatar
Well When we first started the Car on the 2.8inch and 60lb injector tune. we drove the car home the first night with No tuning Just no wide open runs.
Tuning is no harder than using the stock blower setup.
In terms of Pistons I suggest going stock compression or slightly less to avoid timing and tuning issues.
you said earlier the car was hitting boost now were it was not before so is the maf freaking out
Old 07-24-2007, 07:48 PM
  #81
ItalianJoe1's Avatar
This isn't the same car?
Old 07-24-2007, 07:49 PM
  #82
Mikey851's Avatar
IMO, once you get done tuning, run up to 7k and use a nice exhaust the numbers might actually be a little more suprising than what you've mentioned in this thread. It's better to stay on the conservative side before it happens but you made those numbers on very conservative timing at a lower than stock redline.
Old 07-24-2007, 07:50 PM
  #83
rick1217's Avatar
WOW.... that is awsome, great work guys! When will we see some WOT fly bys??
Also, I thought this was Tag's project, are you guys taking over it? or working together?? sorry just a little confussed....maybe I missed something.... Also do you know when we will have a price on this complete kit??
Thanks, and great work guys!!!
Old 07-24-2007, 07:52 PM
  #84
CobaltSS313's Avatar
So was this done on a bone stock car or what. IIRC it just had an intake and that was all? Yah if that was done with a 2.9" pulley and you made 281 imagine what it would make with a 2.5" then 300whp should be a piece of cake, with upgrade pistons, and full bolt ons(I/H/E) and a tune 350whp shouldnt be problem.
  #85
i didnt realize this was a guy from tag. i thought they were using a whipple
  #86
Kritter's Avatar
Wow man, you guys are on the friggin ball with this
Old 07-24-2007, 07:53 PM
  #87
from what i understand, they threw in some 60s and this blower swap, and thats it
we have nothing better to do than sit on this forum
Last edited by chevysalesman614; 07-24-2007 at 07:53 PM. Reason: Automerged Doublepost
Old 07-24-2007, 07:56 PM
  #88
Rent me! per hour
Area47's Avatar
judging by the log
at 7k rpms. you will be at 95.08% duty cycle.
not bad really. 20ms is stuck open, which comes out to be 116.67%
justa heads up
Old 07-24-2007, 07:59 PM
  #89
do we have a larger injector than 60lb/hr available to us?
Old 07-24-2007, 08:15 PM
  #90
yes there are 72lb injectors out there that are direct drop in. I believe Rc engineering still sells them. The 60lb injectors will be fine for most.
Thanks for the quick calculation area47.
  #91
PuSha050's Avatar
wats a stock car make on that dyno???
and i agree.... with exhaust work that thing will really put down some powaa
Old 07-24-2007, 08:16 PM
  #92
The Sunburst Kid's Avatar
sub-muthafuckin-scribed
Old 07-24-2007, 08:18 PM
  #93
Blown 4-banger's Avatar
Ok, is it just me, or did these guys start the twin screw project AFTER tag and finish BEFORE them? Sheesh :shrug:
Old 07-24-2007, 08:20 PM
  #94
Originally Posted by PuSha050
whats a stock car make on that dyno???
good question. i would also like to know
thats what i was saying, but i think this guys from tag... just new to our forum.
or he took the project and finished it for them?
Last edited by chevysalesman614; 07-24-2007 at 08:20 PM. Reason: Automerged Doublepost
Old 07-24-2007, 08:21 PM
  #95
JCswoosher2's Avatar
Maaaannnn!!!! Cant Wait
  #96
PuSha050's Avatar
thats wat i gathered.. bc its the same exact thing.. same machined parts and connectors and what not... but obviously not TAG
Old 07-24-2007, 08:28 PM
  #97
either way, i would like to know how long it will take for mine to come in the mail
i'd like to keep my Cobalt SS Supercharged, supercharged, instead of going turbo. then i might even put my badges back on
Old 07-24-2007, 08:32 PM
  #98
Shortbus's Avatar
Looks promising, hope this one doesnt die like the rest of the guys on here.
Old 07-24-2007, 08:35 PM
  #99
RedEcotecSS's Avatar
i want one... lol
Old 07-24-2007, 08:37 PM
  #100
The only problem with this kit, using that charger in MY position is RPM. The 1200AX has a max rpm of like 14000 rpm, which is a 3" pulley with a 7k rev limiter. However it would be like a 3.5" pulley with my 8100 rpm limit. For normal guys it looks like a GREAT kit
Quick Reply: Rebel Auto Worxs Twin Screw tuning session and Video
