Rebel Ported Head Group Buy
don't worry guys we will test the 8000rpm with stock valves before we send anything out.
taking everything apart is pretty fast ~1hour, putting everything back is what takes long (adjusting timing chain, torquing everything, making sure you don't have any extra bolts, etc.)
i just dont see why you guys are so expensive, even checking around online most places charger around 350-1,000 dollars depending on how much you want done.
Even looking around on a few mustang mags, the highest port and polished set of heads will only run you 1700. I mean can you guys break down your pricing scheme or are you just trying to price gouge because your the only ones on this website offering this?
I mean even if your head quality matches your price, cant you give us a break on something cheaper? I bought a cobalt not a Corvette. Would you consider offering something like just a mild port and polish job?
#36
#38
untill you have solid numbers im gonna hold off, i need to know what the numbers are so i know which cam to get. the only way to optimize a ported head is by matching the cams to it
#41
Interesting. I did not know that. So whould U then have to tell them what kinda of grind #'s u need? How would U know? or would they know for you?
#42
You don't need cams to make big power from a ported head. A fully ported head on the LSJ will yield 20-30whp alone with supporting mods.. ie full exhaust.
#44
The First head should be done very soon. We'll have some real before and after flow numbers from the port work. The head porters we have chosen are the real deal they know what to do when it comes to port velocity and head flow.
#48
Rebel I might be in for a Stage 2 head with assembled upgraded performance camshafts. Can you PLEASE figure out what camshafts could jump us well over that frustating 300whp WALL ? Thanks ...
#50
