red tip spark plug???
Old 03-23-2009, 08:55 PM
MBMCustoms's Avatar
So I have been driving around and my car feels really hesitant and seems to misfire. I took the plugs out and the tips are red on all 4. WTF! I dont know what this is or means and no one at any auto places around here can tell me anything about it either. what to do??? here is some pics:
Old 03-23-2009, 09:02 PM
beansirl's Avatar
have you been running any sort of fuel additive or octane booster by chance?
Old 03-23-2009, 09:03 PM
MBMCustoms's Avatar
i really need help with this. i have burned through 3 sets now
actually i have. i used an octane booster not too long ago but this happened once before then too, a little while after sea foaming
Old 03-23-2009, 09:06 PM
ItalianJoe1's Avatar
Something strange in the gas??
boostedss26's Avatar
That is odd
Old 03-23-2009, 09:07 PM
This happened after the seafoaming??
Maybe there is a connection..
Old 03-23-2009, 09:08 PM
Do you use the same gas station every fill up?
sport08's Avatar
i have never seen that before
Redefined1's Avatar
seafoam should have nothing to do with it. i read up and the only thing i could find is additive to your gas mixture making spark plugs come out purple and red.
Old 03-23-2009, 09:10 PM
MBMCustoms's Avatar
sure do. think i should switch?
so does any of your searching tell how to make it go away. i am on my 4th set of plugs now
SSchargedSS's Avatar
could be the additives in cheap fuel, what gas do you use? offbrand?... maybe a leak and coolant getting in
Old 03-23-2009, 09:11 PM
Redefined1's Avatar
maybe whatever gas you are buying has addictives in it, like shells gasoline or something. just try switching gas stations.
Old 03-23-2009, 09:13 PM
MBMCustoms's Avatar
i use a 7 elevens gas because it is the closest station that doesnt use ethanol.
Old 03-23-2009, 09:14 PM
go use chevron your next two fillups on new plugs and see if that fixes it
Old 03-23-2009, 09:15 PM
I would change your station and see what happens.
Old 03-23-2009, 09:16 PM
sport08's Avatar
yeh all i could find was additives in the gas causing it no "cure" for it though try different gas i NEVER use an quick mart type of gas stations usually there gas sucks try some different gas
Old 03-23-2009, 09:18 PM
Redefined1's Avatar
this guy is on the right track.
Old 03-23-2009, 09:23 PM
MBMCustoms's Avatar
i dont have one near me
I will try some different stations for a while and see if it helps
Old 03-23-2009, 09:34 PM
ShortStack's Avatar
Less than 10% ethanol content wont really do anything... So it doesnt really matter.
Old 03-23-2009, 09:35 PM
MBMCustoms's Avatar
thanks for the info
Old 03-23-2009, 09:42 PM
ShortStack's Avatar
Do you use dexcool?
Thats red, too...
just a thought.
Old 03-23-2009, 10:30 PM
Redefined1's Avatar
i thought dexcool was orange?
Old 03-23-2009, 10:46 PM
GRABBER BLUE MUSTANG GT
Corvettespirit's Avatar
High Speed Glazingthat indicate combustion chamber temp have risen suddenly during hard acceleration,normal deposits melt to form a conductive coating,causing misfires.so change the plugs with colder range.
Old 03-23-2009, 11:04 PM
Redefined1's Avatar
if what he says is true. go 1 step colder and still i recommend changing gas stations.
Old 03-23-2009, 11:06 PM
I'm too JDM for you
BLAZIN07SS's Avatar
well even though copper is the best conductor, it also does wear the quickest. get a new set of plugs and dont use anymore octane booster
Quick Reply: red tip spark plug???
