red tip spark plug???
#76
what sucks is i dont have any of those near me
#77
it may very well be fuel additives: Refineries make a Summer and a Winter blend. It could just be what's in the winter blend causing the discoloration. I don't think the summer blend has gone into widespread distribution yet.....and probably won't hit the northern states till mid-April/early May.
#82
Coolant when burnt will leave whitish residue/deposits. The red is from the MMT or possibly another additive in the fuel. As a side note, if you're ever trying to diagnose a fueling issue such as an injector, you can put in a bottle of the cheap octane boost with MMT and drop in a new set of cheap plugs. Then drive the car for a few WOT pulls and pull the plugs. If one has a lighter red tint you'll know that cylinder is running leaner. It's not as good as per cylinder EGT probes but can be handy for quick troubleshooting.
#92
yeah...I go about 5 miles out of my way to hit up a particular Shell for the 93..there are 2 others nearby, but all they have is 91
all I ever ran in my Cobalt was Shell, same for my S now
#94
i have been using shell 91 lately, changed fuel filter, changed intercooler pump, and changed out plugs to ngk step 1 coolers. i gapped the plugs at .040 and now i only hit 15psi. should i play with the gap till i find the best set-up or can anyone tell me anything that could help me. car runs great now and no red plugs again (yet *praying for the best*).
#95
