Removal of GM Hub.
1 Post
Removal of GM Hub.
I recently have sold my GMS2.
So I need to remove the hub. anyone do this? I have the press I used to get it on and I need to keep the hub so it is usable again. How does one press it off do you think? Thanks for helping from those who have done it and have experience!
1 Post
bump to get some respones.
would this work?
http://www.intense-racing.com/
I have a puller. I am looking at the 24.99 shoe horn that is used to remove the intense hub system.
would this work?
would this work?
would this work?
1 Post
thanks you for your input.
SSnipes, I haven't looked at the GM hub before but is it an offset hub like intense or zzp or is it centered? The intense removal plate should work but we tried to pull a billettflow hub off with it and it was a PITA. Billetflow's hub is centered so there wasn't a lot of room; we ended up having to grind the smaller horseshoe. And in the end I think we used a hydraulic press anyways. Don't try and remove the hub with the pulley on, I can almost guarantee you'll strip the hub.
Getaway_Driver
09-08-2015 09:41 AM
