Removed supercharger. Couple questions.
#51
Oh be quiet this guy is being innovative what have you done for the community
#52
this just in!!!! NEW T*R product! WOODEN REAR SWAY BARS! 6 ply bonded with particle board outershell! choice of colours - teak mahogany and *SPECIAL* DARKMANX Karri (australian hard wood, extra cost) Talk about innovative!!!!Tested by darkmanx....
#55
#56
good one. How about a wooden fmic? balsa wood core with laminated veneer tanks?
#58
The purpose of a throttle body spacer is mainly for naturally aspirated cars. It swirls the air so it mixes better with the fuel. Why would you put it right in front of the blower when its just going to get smashed down into the motor. I think that would swirl it enough dont ya think Like the others said it's just for meth and nitrous ports. As for the blower...i would just shave like 3/32's off of it and use it as a template for when you port it. Or however much you wanna take off.
#64
#67
first, please don't put that piece of wood on your car. What you want to do is bring that wood to a machine shop and say " I need exactly this, but aluminum/metal, hollow is ok", second, that piece of aluminum shouldn't be put their in the supercharger, it would be hard to make it stick also the oval plugs still have space in them, just use JB weld. Third, put the actuator back on or you will blow up your car boosting 12psi at cruising.
****... good catch, who's that sack of **** who bumped it?
Last edited by ecot3c inside; 01-15-2011 at 02:20 PM. Reason: Automerged Doublepost
