return fuel system
Old 07-11-2008 | 12:06 AM
racehtecobalt's Avatar
return fuel system
what exacty is the return fuel system and what do u benefit....and what does it help or prevent.
Old 07-11-2008 | 10:52 AM
rrutter81's Avatar
prevents draining the #4 piston out of your oil pan next change.
Old 07-11-2008 | 11:34 AM
Pully Police's Avatar
A return fuel system provides a return path from the fuel rail / regulator back to the fuel tank.
The benefits are that you can adjust base fuel pressure to allow more range with your fuel injectors, you can have the regulator referenced to manifold pressure - this will ensure that fuel is being injected at base fuel pressure in reference to manifold pressure. (base pressure = 50psi, manifold pressure = 15psi, Therefore - fuel will be injected at 65psi - same goes when you are operating in negative pressure). Tuning wise, this allows you to flatline your IFR curve and eliminate alot of the "gray" area in fuel tuning.
Old 07-12-2008 | 01:31 AM
wow....thanks a million
turbochargedss2012
09-20-2023 01:17 PM
no_ss
10-19-2015 12:58 AM
ashalle2
09-27-2015 04:28 PM
DocSvensk
09-27-2015 03:24 PM
Adiaz1ss
09-27-2015 12:51 AM
