return system fuel rail fitting
#76
ok pricing for a complete bolt on fuel system will be as follows.
KIT 1: $550 for everything but a pump
KIT 2: $640 for everything with a pump, but you have to modify your own fuel bucket for the pump to fit, instructions will be included.
KIT 3: $715 for everything with a modified fuel bucket, there will be an additional $125 core charge on the bucket if you dont send yours back.
contents of kit
walbro gss-342 pump (ONLY INCLUDED IN KITS #2 AND #3)
Aeromotive 13109 Fuel Pressure Regulator
aluminum bracket to mount regulator to firewall
aluminum fuel rail fitting
stainless braided line from regulator to fuel rail fitting
stainless braided line from regulator to tank
acdelco fuel filter modified for this application
summit fuel pressure gauge mounted to regulator
mounting clamps for stainless line from tank to regulator
all neccesary fittings included
all bolts, nuts, screws included
contents of kit
#77
Good prices! We can take it to any performance shop and get this installed correct? or is it easy enough to do it ourselves? Then we need to get a tune for it.
Hell I'd be willing to travel up there to get this thing installed.
#84
#85
dude i would def. be interested in the whole setup.....i just put a stage two kit on my car and i am having a lil bit of problems wit the fuel system...at least that is what i think
