Running a 2.8" pulley with the Stage 2 injectors; OK or dangerous?
That's about sums it up.
You got it bud. That's what I did.
I'd like to throw something in on this also. I've been watching this thread because I too an about to upgrade to a smaller pulley for my stage 2 and am undecided. I've gone away from the 2.8" because seems most likely the 42lbers will be maxed out and the car will most likely be really lean. What I would like to know is if the 2.85" as stated previously in this thread would be safe or not on 42 lb injectors or should I do the 2.9"? Would .05 of an inch in diameter make enough difference anyway?
I've been watching this thread and looked at many other past ones too about this topic. It seems like so many are using 2.8 on stage 2 injectors... Then there are people saying that the injectors are "overworking" or can't supply enough.
I don't know, it would be nice if someone had the answer. I'd be safe and stick with the stage 2 pulley unless you would upgrade your injectors.
I'm probably sticking to stage 2 pulley when I get it, although 2.9 is mighty tempting.
You won't run out of fuel. My wideband said low 11's with the stage 2 tune and the 2.8".
The issue is Injector Duty Cycle and the possibility of the injectors going static (staying wide open). Nobody has had a problem with this that I know of, but there are opinions that it is just a matter of time.
Being safe= stock 3" pulley
Taking a chance= 2.8"
Safer with a 2.85. Safer yet with a 2.9.
#36
Ok, here is the answer. Nobody can tell you because every car acts differently. Now that being said, be smart and get an aeroforce interceptor and a wideband. With those you will be able to tell if the 42's and 2.8 combo work good on your car. And I dare to say that anybody that melted a piston did not have a wideband.
#37
Hopefully the dyno has a wideband connection to watch all areas of the RPM range.
Make a thread after it's done.
#38
Got a question for ya. I was talking to someone about this very same thing and they asked me how HPT can say the injectors are running over 100% IDC. Can IDC actually be measured past 100%?
#39
roth
09-26-2015 12:16 PM
