running rich with mods.. help
alright my mods are
gm stage 2
injen cai
cti header and downpipe
corsa touring exaust
i have noticed while showing off my car that i am blowing black smoke so im guessing im running rich
i wont be getting hp tuners for atleast a month up 2 3 months so i was wondering if i slapped on a 2.8 pulley for now would that help lean out my fuel a bit???
and if i just let it run rich it will damage my car correct??
all help is appreciated
gm stage 2
injen cai
Originally Posted by CbYellowSS
alright my mods are
gm stage 2
injen cai
gm stage 2
injen cai
Im havin the same isued except i have a 2.8 pulley was wondering if i went to a 2.7 would i be better??
I would be careful. Rob just tuned a GM stage 2 car with a 2.8" pulley this morning. With the 42.5lb injectors and the 2.8" pulley, the Injector Duty Cycle was 115%! So, me personally, I wouldn't drop to a 2.8" untill you have the ability to be tuned properly (HP Tuners), a wideband (or on a dyno), and some 60lb injectors. You take a risk at hurting your motor by dropping a pulley without knowing what your AFR is. Just a thought.
well isnt me running rich and blowing black smoke now hurting my car???
and if i did get a 2.8 from zzp i would need that a puller and would i need a tensioner??
There is NO way your injectors would be running at 115% with a 2.8 and 42pounders I am running 11.5 - 12.3 at WOT there are people on here reporting 110% duty with a 2.7. with just the gm tune which runs the injectors if I am correct at around 80% with a 3" pulley and around 95% with a 2.8. Running too rich won't hurt the car as much as running too lean however you should have an a/f meter for at least the dyno to see where you are before and after. Also make sure to disconnect the battery so the computer will learn your new mods.
Originally Posted by glockglade
There is NO way your injectors would be running at 115% with a 2.8 and 42pounders.
Sorry for all the questions, but i'm on a need to know basis.
Originally Posted by LandonElf
Question, did he have an aftermarket CAI setup? And are you using the stage 2 belt with the 2.8 pulley? And how hard is the 2.8 install on a GMPP stage 2 cobalt.
All of the different opinions on Injector duty cycle and pulley sizes seriously concern me. It just further confirms that I will need a wideband to monitor my AFRs when I start upgrading beyond the point I am at now....
First of all, that almost sounds like you're calling me a liar. 2cnd of all, you should be smart enough to know that each car is different. Maybe the person that Rob tuned that was 115% has more bolt-ons and is moving more air. Or did you ever stop and think with the different weather, elevation, and temperatures that results could be different? Last I checked for this time of year going into winter that it gets colder hear than it does where you're at in Palm Beach. Colder air is more dense and requires more fuel. So please don't base everyone else's car off of your specific results.
Not calling you a liar it just must be damn cold up there then .the car is pretty much the same i/h/e and the stage kit but i'm not trying to argue just helping out. If he's running at 115% that is definately not safe. Just get an a/f meter. If you set the a/f correctly on the dyno then you won't need an a/f meter after as long as your mods stay the same and the temps don't change more than usual.
No problem man, and my point isn't to prove who's right and who's wrong, my point is that you just have to scan your car to see what it's doing. That's why I told him not to drop to a 2.8" without a scan tool and HP Tuners (preferrably with a wideband) to be safe. We're all here to help each other.
alright my mods are
gm stage 2
injen cai
gm stage 2
injen cai
to lean = BOOM!!!!!!!
Originally Posted by PlaysWitCars
I ran really rich on the dyno which made my hp drop off after like 4500. Im running 2.8 with 42.5lb injectors with maf-t, cai, header, dp, catback
Do not just throw a pulley on your car you will hurt it .You should get your A/F and we can advise you the correct way . Just a heads up the 2.7 with 42lbs will run out of injector over 6600 so for you guys running this combo shift at 6600 or you'll have a problem sooner or later
BTW there is no happy median with the MAF-T your either rich or lean and mostly both at different RPM's !
Guys get a tune even if it's mail order .
