S/C Falling on its face???
ok...so...ive had this issue recently with my car on the highway. I will be cruising 80 or so in 5th, give it a little gas...and it boggs...it boggs hard! Then it will bog in every gear untill i shut the car off and turn it back on. It has only done this a couple of times, and my mods are in the sig...any suggestions?
It maybe a throttle position sensor...or hopefully just the plugs? Other than that...I'm sure you've got a good tune and have been running it for quite some time...the cat should be good...hmm....
If it's the cat- he'd be boosting well above normal limits.
i still doubt the throttlebody, even a dirty one is unlikely to cause these symptoms.
vacuum leak is possible though.
agentirons
10-16-2015 02:11 AM
