S/C pulley question
Old 04-25-2010 | 09:39 PM
bbbevans89's Avatar
S/C pulley question
Can i move to a 3.25 or 3.1 inch pulley without a tune and also will i need a stage 2 belt?
thanks
Old 04-25-2010 | 09:43 PM
ItalianJoe1's Avatar
I ran a 3" pulley on stock tune and belt. You really only need the stage 2 belt for smaller than a 3".
It's always preferred to re-tune, but you can run a large pulley like that on stock stuff.
You will run out of fuel on the stock injectors anyway, tuned or not. They are just about maxed on a stock car.
Old 04-25-2010 | 10:02 PM
bbbevans89's Avatar
so on 3.1 ill be ok the car will run fine even wide open or would you recommend i use 3.25 cuz i would believe that when the stock injectors max out the car will bog
Old 04-25-2010 | 10:39 PM
Redefined1's Avatar
tune the car.
Old 04-25-2010 | 11:20 PM
corey_osu10's Avatar
if your gonna mess with pulleys and injectors, just tune it
Old 04-26-2010 | 12:39 AM
You are wasting your time using such a big pulley anyway.
Just put a 3" on it now, and then next thing you do should be injectors/tune. GM Stage 1 or equivalent.
Old 04-26-2010 | 01:01 AM
Redefined1's Avatar
i would wait and buy the pulley and injectors together and follow up with a tune.
Old 04-26-2010 | 09:05 AM
LobstaBisque's Avatar
Im on the stock belt and injectors with a 3.1 and the zzp pcm.
Old 04-26-2010 | 09:35 PM
stonny9's Avatar
I am with italianjoe. We both know each other did similiar things at different times. I went to a gm stg 2 pulley aka 3.1 on the stock tune and injectors. on the stg 2 tune and injectors I dropped to a 2.8
yes the injectors are more than maxed but the gm tune runs rich so u are somewhat safe.
I and joe(no longer an lsj owner) both drive them very hard. I redline my car in 1st everytime I drive it more than I care to count.
Old 04-26-2010 | 10:46 PM
Redefined1's Avatar
i dont disagree that you can do a pulley without a tune. i just honestly have to say, why would you do that to your car?
Old 04-26-2010 | 11:49 PM
Because I can?
brandon04
10-21-2015 07:04 AM
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: S/C pulley question
