safe set-up?
ok thanx ....
zzp says its basically a stage 2 wit 20 tweaks .... they told me i would def need a header/dp to run that setup ... not correct?
Without a front mounted heat exchanger to help negate the extra heat caused by the supercharger turning more rpms than it was originally designed to deal with due to the smaller pulley, this set-up will be useless and dangerous. Your intake air temperatures will be extremely high and will rob you of a lot of power. I would also highly suggest a dyno tune as opposed to buying a PCM. You will get a much better set-up from a dyno tune than a tune in the mail. Trust me
im running a 2.8 and 60#'s with a stock exhaust with a highflow muffler and no resonator. my car runs fine but its really restricted. i got a dc sports catback n im just waitin on gettin a midlength header n downpipe which is really gonna open this thing up.
Even with a 2.9 you need a front mounted heat exchanger along with the 60's and a tune. I was running the 2.9 on the GM stage 2 tune and when I dynoed it, I dynoed at 190hp because it was running very lean and very hot. Coolant was shooting out of the overflow tube from then stock heat exchanger and that was after just one run. You can run a 2.9, but you need a front mounted heat exchanger, 60's and a tune.
um under any circumstance having a h/e is one of the most precious things you can have
thanx for all feedback but many mixed reviews .... i want to be safe until i get a h/e and/or header/dp... so 2.9 wit 42s or 2.79 wit 60s wit a zzp pcm(basically a stage 2 tune tweaked)?
Why not 2.9 with 60's and then you have room to drop pullies if you desire? And you dont HAVE to have a heat exchanger and 60's to run a 2.9. Is it smart? Yes? Do you HAVE to have them, No!.
My dyno and, air fuel ratios, spark plugs, and the fact that my car pulled a massive amount of timing out says otherwise.
hey you might wanna check out my thread if your going with a zzp tune...
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/2-8-42s-dyno-results-113169/
Macgyver2484
09-02-2015 05:44 PM
