Santa came early!
Originally Posted by Screamin!
I ground down the bolt to make it work. The my "mechanics" are putting the exhaust on as we speak.
Well, it's installed and throwing codes! P0134 x2
I'm very on the edge if I like the sound of it or not, it's VERY loud. Causes vibrations in the car, and I may be selling the catback and buying a different one. The header and DP I will keep for sure.
Originally Posted by red_wing_2121
Get a vid up ASAP!
#36
Originally Posted by CadetLax13
Before the install did you pull the neg off the battery?
I will try to get vids up, but no promise. I work stupid hours and only have friday/saturday to do it.
I do believe I am selling my catback. I paid $600 for it, I'll let it go for $500.
#40
if you leave your neg off for like 20mins the computer should reset itself and delete the code. try this and after like 20mins hook it back up and then start the car an let it run for about 10mins and then you should be good to go
#48
Originally Posted by p7x
i c, well let me know what they do with that neck down piece, if they put in some 3" straight pipe or something else. I really hope i can order the exhaust with out the neckdown piece.
As for you selling the Cat-back........ YOU ARE CRAZY! You need to get atleast 2k+ miles on it before you decide to sell it. Exhaust needs break in and believe me it gets way better than at first. I love my full Hahn exhaust and I am glad I went with them and nothing else!
#49
Originally Posted by 06noscobaltss
Sorry to burst your bubble but the exhaust only comes with the neck-down piece as it is on there incase you are using the stock DP. The only way to get it off of there is to order that Megan Test pipe or to have a exhaust/muffler shop pull out the neck-down and put in the 3".
#50
So what do you have. You have the full exhaust so do you have this megan test pipe? If you dont whats the point of having a full 3' exhaust with a 2.25 bottleneck.
I bought the megan test pipe and cut it to fit so I technically have a full 3" exhaust now! it is awesome!
