scan gauge 02 voltage?????
k i have the aeroforce scan gauge and was wondering what o2 sensor voltage is lean???how do i read that? if anyone could give me what numbers it is stock and what is safe and what is too lean that would help me alot so i can keep track of how lean i am...i am getting a little knock retard so im sure im a little lean so i need to find out so i can get the intense maf-t and injectors and see if that helps...thanks ahead of time....
The reading unit for 02 voltage is Mv (millivolt), so under load (wot) anything lower than 820 Mv is too lean. You want to see anywhere between 860 and 900 at the most.
But when cruising, anything around 450 to 700 is OK.
