SFPH now has the NGK BKR7E Copper Tipped Sparkplugs!
Like the title mentions, we now have the NGK BKR7E Copper Tipped Sparkplugs, that are required with running a DUB 3.25" Pulley Unit, or smaller Supercharger Pulley. These have to be gapped at exactly .035 for maximum performance, with the use of 3.25" or smaller supercharger pulleys. Hope this helps, as check them out here:
http://www.southfloridapulleyhq.com/...sss/ec_ngk.htm
thats sweet. now what about the fuel requirements? w/ the smaller pullies are they able to run on 91 octain? there only a few states that can only get 91 octain. ie here in cali. so having to run 93 is pretty much impossible. but good work none the less. got any dynosheets on what kind of gains they get from the smaller pullies?
I would not recommend anyone running smaller than a 3.25" pulley on 91 octane, until we have some tuners step up to the plate on tested and proven ECU programming. Hope this helps, as by changing to Copper Tipped sparkplugs one range colder, does in fact lower cylinder temperatures and heat is the worst enemy of any forced air induction engine.
Also, we have several DUB 3.25" Pulley Units installed across the country and are waiting for these Dyno Results to come in. As soon as we do, we will upload them onto the different Cobalt / Redline Forums.
Is anyone running the 3.25" pulley yet on their SS. My thinking is that you would atleast want to do intake and exhaust mods to free up some more air flow first. Anyone have thoughts on this?
Originally Posted by JapEatr
will the plugs help out the performance on the stock motor?
will a colder plug lower combustion temps on the stock boost levels?
Getaway_Driver
40
09-10-2015 09:11 AM
