View Poll Results: should Vaughn go turbo?
Voters: 50. You may not vote on this poll
Should Japeatr go turbo??
So as the poll suggests:
Im at a fork in the road.
Option A:
Send Block to Belvedere for spun molly sleeves
get 10.5:1 pistons
190# injectors
stage 4 cams
solid lash adjusters
smaller pulley
more spray
EWP and relocated oil cooler
or
Option B:
get block bored for my 9.5:1 pistons
keep the ID1000s
sell TVS, my custom header and down pipe
6262 turbo dumped thru the hoodftmfw!!!!!!!!!
ZZP reverse split stage 3 turbo cams
less spray
Option A:
get 10.5:1 pistons
190# injectors
stage 4 cams
smaller pulley
more spray
or
Option B:
keep the ID1000s
less spray
Id like to see you stat supercharged. This always seems to happen with TVS cars. Something breaks and they give up. In the end its your money and you need to be happy with the car, but my vote is stay sc.
I will be giving you a run for your money in the high hp TVS club. We will always stay sc and I plan to push it hard with spray.
In this case though 6262 > TVS. ET could be the same depending on lack of traction but trap speed can be well into the 130s with a 6262.
