Slave cylinder going bad..........
Car has 1600 miles. I broke it in nice and easy and now i'm noticing the 1-2 shift is slipping bad. I have read about this countless times and I was afraid it was going to happen to me. I used to be able to chirp the tires in second but not now. Any suggestions? I got the extended warranty. No mods.
I know there are a thousand posts about this. I read every single one. Somebody said theirs used to do that at early mileage but now it's fine at 16K. At 700 miles I could shift into second and chirp the tires. Now i can't, takes 2-3 secs to grab. Every other gear is fine!
Any suggestions?
Any suggestions?
Originally Posted by 05BlackCobaltSS
The Dealer replaced my Slave cylinder at 7k. My clutch held like a champ after that, but now at 105xx miles, the clutch is mush again.
Originally Posted by Blackbirdws6zzz
I guess I'll wait to see if it gets better first. Was the slave cylinder under the warranty? How did you guys come to that conclusion. I just guess I need to know what to tell them so they don't give me any hassle!
The Dealers replacing mine right now
what did you tell them? I just don't think if I went in there and was like replace my slave cylinder they would do it, don't they have to do some tests and stuff?
They must be morons because the tranny guy thinks its my clutch.... Wierd thing is the cars still driveable and i had to fill up the clutch fluid once so thats what makes me think its the slave cylinder they want to charge me 1320 to replace that. HA RIGGHT!!!
Originally Posted by 2K5SS/SC?
Clutch Job is only $705 out the door at the dealership! That is if you have a clutch to replace it with already.
09-28-2015 12:51 PM
Getaway_Driver
09-08-2015 09:41 AM
