So, I've decided on a 2.7"
Old 05-15-2008, 07:01 PM
  #76
SJSchafer's Avatar
Originally Posted by M-Dub
I got to a 2.80 with Meth on Areas tune! Without Meth a 2.85
Well, I run a 2.85 and I went to 60s.
  #77
BriantheLion26's Avatar
Originally Posted by SJSchafer
Then there's you answer.
Pretty much. 42s came with it when I got it, they are staying. If I would start from scratch... 60s, 2.8", and water inj. ftw.
Old 05-15-2008, 07:02 PM
  #78
M-Dub's Avatar
I was at a 2.85 with 42.5's! But my car was very angry with me!
Old 05-15-2008, 07:05 PM
  #79
InfinityzeN's Avatar
I agree. You staying stock returnless or going return style?
Pretty sure I'm going to go with a return. Don't believe I'll need to go with a larger pump though, my power goals aren't way out there. The return just seems like it would be a lot easier to tune (and could drop the pressure down enough to not have to do any wonky multipliers for the injectors)
Area, what's the smallest pulley size you would recommend to put on the stage 2 injectors for a safe tune?
I'm on a 2.9" and anything past ~6.5k rpm, my AFR goes all wonky. So thats where I'm limiting myself.
Old 05-15-2008, 07:06 PM
  #80
SJSchafer's Avatar
I imagine, and since the question is what area47 thinks is safe, I don't think that 2.85 will qualify as a correct answer.
Old 05-15-2008, 07:07 PM
  #81
M-Dub's Avatar
Area47 was the one that tuned it! So he knows how my car was!
Old 05-15-2008, 07:08 PM
  #82
SJSchafer's Avatar
Fixed. See there's someone going static on a 2.9.
Old 05-15-2008, 07:36 PM
  #83
Doh! Thanks.
Yea, Vince (tuner) and Bob (dyno owner) both figured we could have hit 260+whp if I could have ran it to 7~7.2k rpms. The way the torque curve was looking before it got all wonky, I figure low to mid (263,264). This all in 4th gear pulls. We did one run to 7k, even though it got wonky, and hit 260 and some high change.
Old 05-15-2008, 07:37 PM
  #84
SJSchafer's Avatar
Doh! Thanks.
No worries. I do the same thing with open loop and closed loop. I know what I mean though.
Old 05-16-2008, 12:07 PM
  #85
OneSlowGto's Avatar
Nah, you don't want to do that now.
What do you think your going to put down some crazy awesome numbers?
Old 05-16-2008, 12:18 PM
  #86
SJSchafer's Avatar
Nah, really probably around the 260-270 range. Maybe a little more when I get my ZZP mid length combo in.
Old 05-16-2008, 12:25 PM
  #87
OneSlowGto's Avatar
If you end up putting that down that would be very respectable.
Old 05-16-2008, 12:33 PM
  #88
SJSchafer's Avatar
I don't think that will be a problem, especially when I get a better meth mix and my dual pass in. Right now with the mods I've done since the last meet (meth, cobra HE and return style fuel system) 3rd is pulling almost as hard as 2nd was with just stage 2.
Old 05-16-2008, 12:52 PM
  #89
Rent me! per hour
Area47's Avatar
you really don't want to ride in my car then
:X
Old 05-16-2008, 12:54 PM
  #90
SJSchafer's Avatar
:X
lol. Gimme a minute
Old 05-16-2008, 12:55 PM
  #91
Rent me! per hour
Area47's Avatar
272 cams at 6k > stock cams at 6k
Old 05-16-2008, 12:58 PM
  #92
RedEcotecSS's Avatar
area, what kind of numbers did you put down with your current set up?
Old 05-16-2008, 01:01 PM
  #93
Rent me! per hour
Area47's Avatar
274 on the stage 2 3.06 pulley
11.5 afr. 20-21 degree's of timing
  #94
M-Dub's Avatar
He's waiting for parts to redo it...
It was something like 275 on the Stage 2 pulley!
Yep, what he said! Dangit...
Old 05-16-2008, 01:02 PM
  #95
holy ****, good numbers. that's on meth, right? do you run that tune for a DD?
Old 05-16-2008, 01:03 PM
  #96
M-Dub's Avatar
Yes on meth.... I have no idea he changes his tune more than a **** star gets blown!
Old 05-16-2008, 01:05 PM
  #97
SJSchafer's Avatar
Actually, that's his conservative tune. I won't tell what his DD tune is, but it's a bit more aggressive. Unless, of course he changed it for the cams.
Yea, I know you're cammed, but I am at sea level.
Old 05-16-2008, 01:07 PM
  #98
Rent me! per hour
Area47's Avatar
daily driver tune is 11.9-12.0 afr. timing is more aggressive.
im on a 2.8 now
  #99
so if i kept the mods i have now (in sig) and added a AIS stage 1 meth kit with a nice tune, would it be a noticable gain?
Old 05-16-2008, 01:08 PM
  #100
lsjwannabe's Avatar
hehe, sounds like my dd tune.
Quick Reply: So, I've decided on a 2.7"
