SPDDMN's Winter build/Projects
@thegov I have thought about a little nitrous but I'd like to see what I can do without first.
@slitterell ill be rebuilding the blower with this build, should have added that to my other projects. I'm on a3.1 now actually. I dont want to pulley down too far because of heat.
OEM valves, rockers, adjusters.
Riceburner and I are mulling over a few ideas on iats and I've been watxhing blackwaters thread pretty close.
You won't get as hot with cams and ported head because you will be making less boost. You get heat from the compression of air.
But good thread. Sub'd for results
I'm gonna have to do some r&d with pulley sizes and the only reason I'm starting at 2.9 is I ordered a 2.8 from zzp and they sent a 2.9. Then in the process of trying to install it the damn gm special bolt tool broke so its just be collecting dust.
