stage 2 question
stage 2 question
so i went to my buddys shop to get my stage 2 installed... they got the sc off and they put the pulley puller on... ended up snaping the bolts on the puller that was rated at 600lbs or something... so now they said they will have to send it out to a place to get it pulled off by a press... does this sound right? and how much force should be used to get the pulley off?
They must have been doing something wrong or had a defective puller. I pulled mine off with the supercharger sitting on the tailgate of my pickup with my father holding it down.
that makes me mad lol i talked to the tech and he said he broke his pulley puller and even tried heating it up a bit cuz the aluminum expands faster then the steel... and still nothing
Originally Posted by MrStaticX
is it bad to get the reflash before the smaller pulley goes on?
To get my stock pulley off we had to put it into a 12 tonne press and it was maxxed out. Stubborn bitch for sure.
were taking it to a 2 ton press... hope it does the trick lol
and yes i do have the injectors in
Good luck. Some guys on here have had no problems. My stock pulley was garbage afterwards cause it got bent in the removal process. Glad I will never need that big bastard again.
