Stage 2 Question
Stage 2 Question
how many psi of boost will the GM stage 2 deliver? what is the diameter of the pulley it comes with? when i read about a 2.9 pulley or a 2.8 pulley that means the diameter right? smaller pulley means the supercharger spins faster at the same rpm which is more boost, but how much? how many psi with 2.9, and how many with 2.8?
wow you should read and search a little more, but FYI stage 2 is 15 lbs of boost, 3 inch pulley, every .10 off the pulley is about 1 lb of boost, and you'll need a tensioner with a 2.8 pulley or below, possible even with a 2.9, and get cooler plugs whatever you do.
I have the stage 2, it produces 15 psi, I put the gmpp exhaust and it made a world of difference. Still havent gotten a cai yet but it's next on the list...sorta I still need a TD and shifter
