View Poll Results: Is ur clutch slipping with stage 2 or 3?
YES
52
43.70%
NO
67
56.30%
Voters: 119. You may not vote on this poll
Stage 2 and Slipping
Just started noticing that pulling in 3rd and in 4th gear my clutch slips a lil.
Any suggestions, such as;
approaching GM about it?
just get an aftermarket?
waiting till it's craps out?
the 2-3 shift you can hear some slipping but it's only every once and a while when nailing it.
Hopefully I'm gonna be able to grab a clutchmasters soon!!!
Well, I had the same problem P7X. I decided to go with the aftermarket clutch. My ClutchMasters FX300 is awsome. I would definately recommend it as an appropriate upgrade.
I just need to get rid of this squeal I have. I may have to pull the car apart again to replace the slave cylinder again. I may have got a bad one.
i just bought my cobalt about 2 months ago i havent really tried to launch it too many times because of shitty traction but i have noticed when i do try to punch it off the line and it starts to spin tires real bad I will kinda let off the gas then put the pedal down again and when i shift into second the engine will just kinda rev up almost like the clutch is not fully releasing and I can smell my clutch burning? wtf? is that about is anyone havin that problem or am i doin something wrong? and what is the best way to lauch this damn thing i mean i have a 01 supercharged z24 and it aint this hard
The GM clutch itself isn't the weak point it's what controls it.
I had slippage problems when 100% stock, after taking it to GM it was a faulty slave cylinder. The slave wouldn't let the clutch engage 100% causing it to slip every once and a while.
I had a new GM clutch & slave replaced under warranty at 7800 miles and added my Stage 2 at 7900 miles. I haven't had any slip so far, when I down shift into second at 40mph I can spin the tires with ease.
I hate to say it but if your clutch is slipping even slightly, it will only get worse and everytime u feel it slip ur making it worse so if u plan to drive where it makes it slip its going to eventually die, it happend to me and i'll admit its my fault but clutch slippings isn't one of those things that go away.
I know this is common knowledge but i figured id state it.
Originally Posted by Gorilla unit 33
WTF... i'm like 3 miles from 12,000. if i drive from here to the dealer i'll be over. think i can call and slide it in at the dealer
Well I have just over 5K on the car and the other night I shifted from 1-2 and got on it and with the clutch all the way out and my foot of it it slipped.
Im pissed! I have been driving a stigh for 10 years and have never had a clutch go out that had less then 100K on it. I drive a semi for a living and know what im doing and it still started slipping on me.
It will only slip in 1st 2nd and 3rd but if you get on it to hard it will just slipp and it seams to be geting wores the longer I drive it.
Its parked right now and I will take it to the dealer then next time I get home as Im on the road right now.
Later
Later
Originally Posted by MOD MONEY
whoops! I thought this was about stg2 clutches slipping. My spec stg2 just isnt enough I'm getting clutchmasters 6 puck
i want a fidanza flywheel and Clutchmasters stage 4 with the 4 puck or 6 puck IDK the diff between pucks ones more agreesive i guess
i want to make sure if im spending the money-that ************ never slips again
Originally Posted by 2K5SS/SC?
The FX300 at first is a biotch! Once it's broken in, it feels ever so slightly firmer than the stock clutch did. It is still extremely drivable in traffic.
Anyone personally know how long it takes to swap a clutch? Never done one before. Might even have to get it done which is even more money!
