Stage 2 to Stage 3 GM Kit
order the stage 3 kit from CED, install, go to dealer get tune = done?
2006-2007
http://www.crateenginedepot.com/stor...P1689C196.aspx
2005
http://www.crateenginedepot.com/stor...P1724C196.aspx
stage 3 questions and answers
http://www.crateenginedepot.com/stor...s-W57C196.aspx
I also recommend the option B which will work well with the stage 3 dual end pass
http://www.crateenginedepot.com/stor...P1838C196.aspx
2006-2007
2005
I'm stage 2 also.
I'm gonna go with zzp stage 3 though seems like a good deal. Not too expensive, $400.
http://zzperformance.com/cobalt_ion/...1055&catid=188
2006-2007
2005
2006-2007
2005
http://www.ottperformance.com/store/...ate-11p889.htm
http://www.zzperformance.com/cobalt_...ts1.php?id=855
http://www.ottperformance.com/store/...Kit-11p924.htm
http://www.zzperformance.com/cobalt_...ts1.php?id=980
A 2.99 from the classifieds or smoothflowpulleys:
https://www.cobaltss.net/forums/sear...y=2.99+OR+76mm
http://www.smoothflowpulleys.com/Stage2.html
and the GMS3 tune from Trifecta WITH A/C unlocked and HPT accessibility using your stock PCM:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/trifecta-stage-3-faq-214518/
2006-2007
2005
2006-2007
2005
I am GM Stage II also.
2006-2007
2005
2006-2007
2005
Well i am in the same spot you are but have decided to go this way. I am getting the 76mm pulley from ottp for 50.00. Then when trifecta comes back on the 15 of August i will be doing the stage 3 ecu flash + Trifecta tune. Also buying the HP Tuners Suite.
That should net me some pretty good gains. Dont have a CAI or exhaust yet but will be adding those in about 15 days after i do this.
I was told that the stage 3 + Trifecat tunes brings 20 to 30hp on top of what stage two puts out. Waiting for Vince to get in touch with my local tuner.
Best of luck in whatever you choose to do.
Stage 3 from Trifecta is the same as Stage 3 from GM, with the exception of being able to modify it with HP Tuners and use your A/C.
GM rates S2 at 241hp, and S3 is rated at 260hp with HOM enabled (GM never rated it with HOM off, but its somewhere in the middle). Its not a major increase in power, but then again its not a major decrease in pulley size either, so its good for what it is.
If I were you I'd go ahead and drop down to a 2.90. The leaner mixture of GMS3 allows for a little more injector breathing room and you'll definitely make more power.
wow thanks alot guys so yah i decided to go with the GM stage 3 kit. Im just gonna upgrade the "hptuners, get a pulleu and injectora " like everyone says. Thanks for the help!
09-28-2015 12:51 PM
