Stage 2 Supporting Mods
If i go with the OTTP Stage 2 kit with the 2.8 pulley and the 60lb injectors, what other mods will i need i have a DC Sports CIA intake right now. what else am i looking at needing? Header/dp and keep stock cat? or get an exhaust system and header?
i just put the stage 2 on and i just through a code p0171 . i sprayed carb cleaner around all vacuum and injectors and the supercharger ideal didn't change. is it the 02 sensor ? let know if any one knows
just dont want to hurt my car you know
Last edited by 07superchargedcobalt; 09-08-2010 at 11:50 PM. Reason: Automerged Doublepost
Check your fuel trims, I bet they are ABOVE
20
A tune should help, but check for vacume leaks first.
