Stage 2 ZZP
Old 08-23-2018 | 10:52 AM
thatstripedbalt's Avatar
Stage 2 ZZP
Looking to go with a stage 2 zzp sc kit with 2.9 pulley, zzp stage 2 belt, 60# injectors
Going to be running this with the zzp 3" cai and cat back zzp exhaust
Should I get the S3 heat exchanger to help with the cooling or is this not necessary?
Old 08-23-2018 | 10:55 AM
Also would be getting a tune but not sure where to get it from
Old 08-23-2018 | 12:03 PM
user 72239's Avatar
I'd get Option-B and dual pass over S3 heat exchanger
have you made sure your supercharger coolant pump is working?
Old 08-23-2018 | 03:53 PM
So you’re saying to get the dual pass endplate instead of the heat exchanger? And sounds dumb but how do you check to see if the pumps working? Can only find videos on intercooler pump or is that the same?
Old 08-23-2018 | 04:56 PM
user 72239's Avatar
Yeah its the same.
turn car on, check your overflow and see if you have coolant flowing.
Old 08-23-2018 | 05:04 PM
Yeah its the same.
If it's a stock tune there is a good chance he'll have to wait till after the car is at operating temp for a bit
Old 08-23-2018 | 07:50 PM
As the car sits now it’s stock and at the dealership right now, picking it up in a few days, trying to figure out the best way to build it
QBalt
Tuning
10-06-2013 09:00 PM
YelCal7
04-20-2012 07:53 AM
bobbyjohn681
02-16-2012 01:35 PM
DEZZIE41
01-13-2011 01:27 AM
chevysssc
10-12-2009 04:59 PM
Quick Reply: Stage 2 ZZP
