Stock Boost Psi?
Old 06-16-2007 | 01:14 PM
Onyxd04Redline's Avatar
Originally Posted by justin04
its not the power its the boost and no matter what i fuel i run still no boost..............
How does the car run on 87? Does it ping?
Old 06-16-2007 | 01:20 PM
justin04's Avatar
naw runs good actually feel like it runs best on a mid grade............ but the i think the only thing that it could be is the filter............ do u know if the filter just screws on?
Old 06-16-2007 | 01:22 PM
What do you have a CAI? Airbox mod? If should be clamped on.
Old 06-16-2007 | 01:23 PM
NYC_Eddie's Avatar
well i just got bought mine on the 12 with 1/2 tank in it..didnt know what kinda fuel the dealer put into it...i put 93 lastnight and also did oil change...and my boost show just shy of 10 psi..im goin to check now for any cracks in the lines...off topic its a f-ing pain to do the oil change well to replace the oil filter is another project in its self...im still wondering if my car is a g85 package i did a search to see and from what they say..i can say i have it then..but not really sure cause the dealer i bought it from didnt know **** ..all he new is that its s/c...and couldnt tell me crap about the car except that its in great shape( 7300 miles on it and only paid 15k for car...steal...i love florida)
Old 06-16-2007 | 02:30 PM
ralliartist's Avatar
Originally Posted by 95cobra68camaro
bone bone stock i was seeing 11-12.5 on the gauge, after i got the limiter extended i have logged 14.8psi still stock on a 65-70 degree day
same here!
Old 06-16-2007 | 02:39 PM
arng22's Avatar
and your not in 1st gear right? go down a high way rip from 40-90 and you will see 11-12.5 lbs of boost
Old 06-16-2007 | 03:36 PM
Mikey851's Avatar
i put both manly 87 but i run a tank on 93 every week. the only think ive done different is took the bottom off the airbox. jackolupe thinks its a clogged air filter..... there is no cracks in the lines and the bpv is workin moving up and down.....
the sticker with all the option codes is in the trunk, on the left side, under the carpet. Cant miss it. It's silver in color with black text.
Old 06-16-2007 | 06:26 PM
justin04's Avatar
so i mean has anyone else had this problem?
Old 06-16-2007 | 07:16 PM
Mikey851's Avatar
The reason why your fuel octane was pointed out above is because if the computer detects knock it could cut boost out for protection. I'm actually not positive on how much control the computer has over that but it doesn't matter because you should run premium or AT LEAST mid grade. 87 octane will cause the computer to adjust timing to avoid knock; depending on your environment and driving conditions it varies on how much the computer must retard the spark and if it's bad enough the computer may cut some boost (Like I said I don't know to what extent it can do this, but it's the easiest place to start).
Old 06-16-2007 | 07:23 PM
an0malous's Avatar
87! dear god that poor engine.
did you not read the manual?
did your dealership not tell you your car needs premium fuel?
If you cant afford a few bucks at the pump, you shouldnt have bought a car that needs premium.
Old 06-18-2007 | 09:55 PM
  #36
justin04's Avatar
anyways i took it to the dealer and they said it was the bypass valve................. and i run 93 in my car btw.
05-28-2022 03:47 AM
Sl0wbaltSS
11-21-2018 11:11 PM
717ssbalt
10-02-2015 04:01 PM
09-27-2015 08:53 PM
OPCrer
09-27-2015 08:11 PM
Quick Reply: Stock Boost Psi?
