Stock Heat Exchanger Mod....lower IAT2 temps 40 degrees
Old 07-28-2013, 03:44 PM
  #101
jrmotosports 88's Avatar
click
Old 10-27-2013, 03:41 AM
  #102
South Central *********
JapEatr's Avatar
bumper is already off, im doing this tomorrow
Old 04-05-2014, 09:25 PM
  #103
chris88z24's Avatar
Bump. Trying this again tomorrow, lol.
Old 04-06-2014, 12:17 AM
  #104
Ac delete ftw
Old 04-06-2014, 12:09 PM
  #105
chris88z24's Avatar
Ac delete ftw
No way!!!
Old 04-06-2014, 12:23 PM
  #106
Only way
Old 04-06-2014, 12:43 PM
  #107
chris88z24's Avatar
Only way
Not up here in the rainforest. You will not survive.
Old 04-06-2014, 04:14 PM
  #108
chris88z24's Avatar
There's nowhere to bolt the heat exchanger to on the condenser after you bolt the condenser to the radiator. Waste of time.
Old 04-06-2014, 05:41 PM
  #109
06cobalt racer's Avatar
Did u use longer bolts like it says in the very first post?
Old 04-06-2014, 06:13 PM
  #110
YelCal7's Avatar
My advise to get longer bolts and get bolts sleeves to hold it in place. You will see both sides are not the same measurement.
Old 04-06-2014, 06:17 PM
  #111
chris88z24's Avatar
Yes I used longer bolts. What are you doing, using the same bolt to hold both parts on there?
there's nowhere on the condenser to bolt the h/e to.
Old 04-06-2014, 06:18 PM
  #112
chris88z24's Avatar
I did exactly that. Fit horribly and the h/e sat way too low. It might be ok in Florida but up here that thing will be destroyed after one winter.
Not worth the hassle.
Old 04-06-2014, 06:37 PM
  #113
YelCal7's Avatar
I did that and I did strap it on top of h/e. It did hold up well before I got rid of it to get Cruze then got rid of Cruze and got LNF. LOL!
Old 04-06-2014, 06:38 PM
  #114
YelCal7's Avatar
I would say best bet get ZZP Stealth H/E and be done with it. Have them weld the bung for Option B. It's a must for LSJ.
Old 04-06-2014, 06:43 PM
  #115
Powell Race Parts's Avatar
big race griffin, single pass. end of story
Old 04-06-2014, 06:44 PM
  #116
YelCal7's Avatar
Or that, either way work best.
Old 04-06-2014, 06:47 PM
  #117
chris88z24's Avatar
Stock, hold gas pedal down longer to accelerate. Lolol
Old 04-06-2014, 06:49 PM
  #118
^^^lol. after probably 4 years , I figured out why Zoomers single pass was inferior in independent customer tests, to dual pass, back to back/ car to car. I wonder what the deal is on the stealth....
Old 04-06-2014, 07:24 PM
  #119
chris88z24's Avatar
Just so we're clear, here's a picture of the stock condenser. I rotated it to show how it bolts onto the car like so: There are two places where a bolt can pass through on each side to hold the condenser in place. The tabs on top fit into the plastic tabs on the radiator. If you use the two bolt holes to mount the condenser to the radiator, then there's nowhere to bolt the heat exchanger to. The only other way is to use the same bolt to hold the condenser AND the heat exchanger in place, which makes for poor fitment.
Take Powell's advice or leave it stock!
Old 04-06-2014, 09:48 PM
  #120
chris88z24's Avatar
I just noticed something - the bracket on the OP's heat exchanger is different from mine. My car is a 2007, not sure if that makes a difference or not.
Old 04-06-2014, 11:19 PM
  #121
all brackets were the same all lsjs from redline 04 to cobalt 07
stock wth an option b bleed is as good as you can get in terms of little money spent for good results.
Old 04-07-2014, 12:47 AM
  #122
chris88z24's Avatar
That ZZP Stealth looks nice but how the hell does it bolt up in front of the condenser? In their pics it looks like the condenser is bolted to the radiator but then where does the stealth bolt up to?
Old 04-07-2014, 12:49 AM
  #123
The stealth bolts up to the crash bar and the hood latch bracket
Old 04-07-2014, 10:28 AM
  #124
chris88z24's Avatar
Drilling required?
Old 04-07-2014, 11:20 AM
  #125
nope you simply remove two nuts that are already there for some reason or another, slap her on over the studs and put on the new nuts included with the h/e
it's nice how zzp did that, what with it being in front of the a.c. condensor. granted, it is not the best fit by any means. i couldn't fit my a.c. condensor back in, but that may be user install error. the input and ouput lines stretch just past the radiator to stock locations.
Quick Reply: Stock Heat Exchanger Mod....lower IAT2 temps 40 degrees
