Stock Heat Exchanger Mod....lower IAT2 temps 40 degrees
#112
Not worth the hassle.
#119
Just so we're clear, here's a picture of the stock condenser. I rotated it to show how it bolts onto the car like so: There are two places where a bolt can pass through on each side to hold the condenser in place. The tabs on top fit into the plastic tabs on the radiator. If you use the two bolt holes to mount the condenser to the radiator, then there's nowhere to bolt the heat exchanger to. The only other way is to use the same bolt to hold the condenser AND the heat exchanger in place, which makes for poor fitment.
Take Powell's advice or leave it stock!
#122
That ZZP Stealth looks nice but how the hell does it bolt up in front of the condenser? In their pics it looks like the condenser is bolted to the radiator but then where does the stealth bolt up to?
#125
nope you simply remove two nuts that are already there for some reason or another, slap her on over the studs and put on the new nuts included with the h/e
it's nice how zzp did that, what with it being in front of the a.c. condensor. granted, it is not the best fit by any means. i couldn't fit my a.c. condensor back in, but that may be user install error. the input and ouput lines stretch just past the radiator to stock locations.
