Stock Heat Exchanger Mod....lower IAT2 temps 40 degrees
#127
So I pulled the trigger and picked up the ZZP stage 2 2.9+60's
IAT's were doing good but around noonish they climbed to 150 stopped and would only drop when moving. Idle the slowly climb to 150+ but WOT is ok hitting 130.
My IAT was not reading for some reason so I don't know what my compare was but outside temp was 77 according to the dash.
Not sure if I wanna do option B or this. I have a new condenser coming in today because a piece of tire hit it and knocked a hole in it. So I am not sure again about moving this stuff around....
Think I'll order a B and go from there. Or pick up a junkyard reservoir and do it up.
#129
I am thinking of running a relay and switch to kick both fans on if the AC is off if I know I am going to be getting on it and need better air flow when I stop.
I really do not feel comfortable with moving the HE core to the front of the pack as it can be damaged easier.
#131
#133
I had stock cooling with front mount and flow through tank holds a gal and a half but temps were always 30+ difference or more with ac on. Removed front mount and moved stock he and foamed the gaps and fully hot sat parked, with ac on or off i now have iat 102 iat2 124 very pleased with that will do some wot pulls as i havent left town and temps stay there. Normally sitting theys spike 140-150 with ac now nothing over 125
