Stop the Madness! 2.8" pulley and 42lb. injectors is No Good!
Old 11-15-2006 | 10:31 AM
  #126
distillion's Avatar
im gonna try to get my boy on the dyno today with the 2.8, a lil last min but its worth a try
Old 11-15-2006 | 12:07 PM
  #127
cds00bsmg's Avatar
Basic Summary:Think of a fuel injector like a garden hose with a trigger nozzle on it. At say 1/4 trigger its operating at 20%. At 100%, its giving you all its got. If you demand say 100%+ from it, it CANNOT give you that. Its at its maximum at 100%. Sorry, no 110%+ like coach demanded of you back in highschool...
Yes, in most, if not all cases, 2.8" w/ 42.5injectors are running fine AFR setups. However, injector failure is likely due to high IDC.
Diagram:
http://static.howstuffworks.com/gif/...on-diagram.gif
A injector generates heat, the plunger can, and most likely, definately, will get STUCK OPEN. Its electronically controlled, demanding more than it can flow is putting excess stress on it, and is going to at some point wear it out.
I think we've extablished that, we have a member who has experienced it on his car. We have members who claim to have seen it occur on other vehicles. What more are you looking for to see that it is not safe?
HOWEVER, it does vary setup to setup, car to car. The only way to know what is going on for sure is to have the appropriate monitoring devices on your car, and have the car correctly tuned.
Old 11-15-2006 | 12:18 PM
  #128
CTCOBALTSSS's Avatar
Diagram:
Very good info cds00bsmg. Thank you sir!
Old 11-15-2006 | 12:24 PM
  #129
red-SS's Avatar
Originally Posted by Boost Fr33k
from what people have told me so. you can run deff run 44lb and prob to 60lb injectors but from my point of view 50lb are just right, just make sure the numbers on ur tune are safe.
im planning on going with a zzp 2.85" with PTE 50lb injectors as well.
hope i helped
cool thanks. I think I will be running the 50lb injecters.I don't wan't to screw the motor
Old 11-15-2006 | 12:25 PM
  #130
Good call red. Here is a link to 50lb. injectors incase you need it.
http://www.cobaltperformanceparts.co...ion-p-215.html
Old 11-15-2006 | 12:38 PM
  #131
red-SS's Avatar
thanks for the link
Old 11-15-2006 | 12:46 PM
  #132
distillion's Avatar
why dosnt anyone have the 50's then???
Old 11-15-2006 | 12:51 PM
  #133
thanks for the link
Anytime bro!
Good question. I think it's because most people are just finding out about them.
I don't know exactly know how long they have been out.
Old 11-15-2006 | 04:07 PM
  #134
Asstyme's Avatar
I'm still waiting to see all these people running the 2.8 with GM stage 2 to start blowing up. You might find one or two people that have a problem and will blame it on that setup but overall I think you are seeing and will continue to see fewer problems with this setup than you do with the "custom tunes" or the guy that has every after market mod bolted/wired in.
It's very hard to believe that a 2.9" will be all good and then just by going down .1" to a 2.8" your gunna blow
You want to play ? Sometimes you will pay Sometimes stock motors blow up too
Old 11-15-2006 | 04:35 PM
  #135
meister's Avatar
Originally Posted by FAST06SS
How can you contradict yourself in the same sentence and expect us to believe you??
Weather conditions sure the hell will affect your tune! Cold air needs more fuel, hot air less.
The code you are getting is because of a lean mixture at idle and part throttle, and has nothing to do with what is happening at WOT. Your 02 sensors are not even being used for WOT fueling. Your 02 sensors are having to over compensate beyond their normal thresholds to try and achieve commanded STOICH.
[/QUOTE]
Like I said, if the car is tuned PROPER it will compensate for the denser air. A lot of "tooners" are using improper methods for tuning where weather will drastically change a tune.
Using our methods, which have already been proven and proven in the ford world for quite some time now work perfect, no one will have any issues.
Cold air is more dense, which means you are seeing a higher frequency on the maf. Depending on how the tune is written, the higher frequencys on maf table are already adjusted and your air fuel will be correct.
The code that is appearing is from part throttle fueling, not wide open throttle fueling. Again, if tuned PROPER no issues will occur with changes in weather, bp, etc
Old 11-15-2006 | 05:03 PM
  #136
Mase's Avatar
The graph in post #1 is with a ZZP 2.85" Pulley I had mistaken when I posted 2.80". The people who state they are getting 90% duty should post their log file as proof.
I don't understand all this debate over 45lb, 50lb, etc. injectors. Just throw in the 60lb's, get it tuned and your set for any future upgrades or you can install a meth/water kit as I stated before.
Old 11-15-2006 | 05:05 PM
  #137
StinkBOMB's Avatar
^^ Some people are worried about the 60's being too much with a 2.8, though I haven't seen anyone post anyting up proving they are too much for that load.
Old 11-15-2006 | 05:30 PM
  #138
SS Gordon's Avatar
I have taken my 2.8 off for now but it was a screamer & I didn't hear any knock but lets face it how can you hear it over the screaming SC.
I've only done a couple small mods
Stg 2
Injen CAI
Ingals dampener
Pully Boys 2.8
Now today I was driving with the 3" Stg 2 pully & man what a diferance as the 2.8 gave me much more bottom end & I miss it already so whats the best method of monitoring my motor as I'm old school & don't know alot about the tuner world as of yeat
I do have a ODBII on my laptop & I can get real run time scans or do I just need to buy a system?
Thanks for the heads up on this whole issue as I had no problems, the car ran great but you know it don't take long to damage a motor & I want to get it paid off before I blow it
  #139
cds00bsmg's Avatar
I doubt you will see ayone "blowing up". I wasn't claiming that anyone would blow their motor, just that running the injectors at a high duty cycle will/could eventually lead to injector failure (stuck open).
HPTuners will take care of this concern. It just takes proper tuning.
A wideband oxygen sensor will monitor your AFR. The aeroforce interceptor can monitor knock. (Im not sure if it can monitor IDC). HPTuners can monitor IDC, and IPW (injector pulse width). (Not sure if there are other means to monitor the last two)
Old 11-15-2006 | 05:35 PM
  #140
StinkBOMB's Avatar
^^ Agreed. I may just have to stop being such a cheap ass and buy HP tuners. I'm tired of fretting over this and I'm ready to get my hands dirty.
  #141
SS Gordon's Avatar
Ok so to put larger injectors in I would have to have it tuned afterwards right !
And also if you do run above the injectors limit you can cause engine damage over time can't you from running lean ?
Old 11-15-2006 | 05:42 PM
  #142
cds00bsmg's Avatar
A)To run 60lb injectors, yes, you will require tuning.
B)If you were to run lean, yes. From what I have seen, and what others are posting, leaning the car out isn't an issue with the 42.5lb injectors. Their AFRs are fine, and they are running withing safe rich/lean conditions. The injector duty cycle is the only issue.
Here is a earlier post, also giving example of injector failure/problems on a SS/SC due to letting them go static.
It can be found on page 4, first post.
https://www.cobaltss.net/forums/show...t=28190&page=4
Here is the post
Originally Posted by djt81185
prob 2.4
I have 75%idc with 2.5 and 60lbers.
My buddies 06 ss/sc with injen, 2.9, and gmpp catback has idc's of 154% max lol...If u go on a WOT run u can feel the injectors seize shut at about 130 ish and the car just like feels like it hits a wall until the injectors cool down enough to spray again.
Dan
Old 11-15-2006 | 09:20 PM
  #143
Wyoming_Bass's Avatar
ok the HTP scan that levi will post or if you want ill post it is from my car. 85% is the highest i have seen EVER with 3 different tunes
2.8 South Florida Pulley
42# injectors
Opened Airbox w/ K&N Filter
The only issue i am having at all is a 5* of KR at 5800 rpms it goes back down to normal @ 5850rpms
again like Levi said we are around denver i personaly am at 6800 ft 90% of the week. I have tenative plans to go get dyno tuned after the first of the year. I keep reading that people just tune and dont know what they are doing. I trust the guy that tunes and works on my car more than i trust GM. There is no need to worry an entire group over a few BAD eggs. Yes you mod at your own risk. however keep in mind (this has been said before) each car is different. Hell putting the 2.8 pulley on my car caused the S/C to make noise... cars make noise after you mod get use to it. If your scared to mod then dont. if you want to mod do it. if it breaks fix it and figure out why!
Old 11-15-2006 | 10:15 PM
  #144
beamSS's Avatar
Dont you think maybe its the type of 42# injectors used that is giving us different results? idk just asking
Old 11-15-2006 | 11:05 PM
  #145
i dont know.... i am using the gmpp stage 2 42#ers
Old 11-16-2006 | 12:16 AM
  #146
SwizzDSMSS's Avatar
Remember some injectors read higher than their real cycle duty. So maybe our 42's do that?
Old 11-16-2006 | 01:44 AM
  #147
leviticus88's Avatar
42# injectors
Its your scan so I'll let u post it.
Nice sig by the way!
Old 11-16-2006 | 07:07 AM
  #148
Rage915's Avatar
well im guessing im ok im at high elevation (4800) ran my car on the dyno again and my car is running perfect, sucks though cause pushing 16psi with a 2.8 pulley but o well ill see if they will let me post up my screen shots
Old 11-16-2006 | 10:03 AM
  #149
mken's Avatar
Ok, now what? I have the 60#'ers in now and I am showing an injector pulse width of 14 ms @ 6900 rpm. So, according to this injector duty cycle calculater, I'm still at 85% IDC. Do these calculaters found on the internet give accurate results, or does my car just hate me?
Old 11-16-2006 | 10:23 AM
  #150
FAST06SS's Avatar
No, you are just running to rich!!! Shoot for 860-870 on the 02's
Quick Reply: Stop the Madness! 2.8" pulley and 42lb. injectors is No Good!
