stroker lsj build
Old 01-07-2013, 10:43 PM
  #226
574
574's Avatar
Is that wommpopopopopopopopopop?
Old 01-07-2013, 10:57 PM
  #227
TStone's Avatar
hahahahaha ^ i like that
Old 01-07-2013, 11:00 PM
  #228
Tjolley's Avatar
yes sir
Old 01-08-2013, 12:13 AM
  #229
InfraRedline's Avatar
Wot box = fun
Old 01-08-2013, 07:30 AM
  #230
freakta's Avatar
sorry for the wait but at least you can do other things while you wait
Old 01-08-2013, 08:14 AM
  #231
Tjolley's Avatar
thats true...i need to finish my head. havent touched it in weeks.
Old 01-08-2013, 01:47 PM
  #232
ebristol's Avatar
Where was his placed?
Right behind the drivers door. Side exit.
Old 01-11-2013, 09:17 AM
  #233
Tjolley's Avatar
well this sucks...
hopin to dyno this weekend and i cant figure out y im getting a massive miss fire at 5500 rpm..
i noticed my injectors r goin static then also..
they normaly hold to about 7500..
the car seems to run and drive fine..
ive been told possible fuel pump issures.
Old 01-11-2013, 09:23 AM
  #234
574
574's Avatar
Originally Posted by Tjolley
well this sucks...
Plug gap?
Old 01-11-2013, 09:27 AM
  #235
Tjolley's Avatar
ngk coppers
.032 gape
Old 01-11-2013, 09:29 AM
  #236
574
574's Avatar
If your suddenly running out of fuel maybe your plugged somewhere. Check the fuel filter
Old 01-11-2013, 09:34 AM
  #237
Tjolley's Avatar
ya im gona try that this weekend..
now the only thing ive changed is i was running
ngk bkr9eix plugs with a 032 gap..
i was told to stick with coppers so i switched.
Old 01-11-2013, 10:00 AM
  #238
c130aviator's Avatar
grounding issues? are all your contacts clean from your valve cover to your block and so on. If you painted the vc you have to clean off the contacts under the strap that is next to your cam sensor. Also clean off anything around the coil on plug bolts, they are the negative ground for our car.
Old 01-11-2013, 10:18 AM
  #239
Tjolley's Avatar
oh good point...ill definitly check that out
Old 01-11-2013, 12:00 PM
  #240
armcclure's Avatar
Bkr9?? That's a damn ice plug l
Old 01-11-2013, 12:09 PM
  #241
574
574's Avatar
Damn I was really looking forward to these results too
Old 01-12-2013, 02:27 PM
  #242
Tjolley's Avatar
made these today..
balance shaft chain delete kit...lol
Old 01-12-2013, 02:29 PM
  #243
armcclure's Avatar
Hey... You got the dims on those? Obviously could just measure the bearing surface but I wasn't sure how much press to put on them...
Old 01-12-2013, 02:31 PM
  #244
Tjolley's Avatar
i gave them 005 press...
toss them in the freezer and the should slide right in
Old 01-12-2013, 02:33 PM
  #245
armcclure's Avatar
That would work. I also thought about making it a 2-price part with a bolt, but if the press is correct that's better.
Old 01-12-2013, 02:44 PM
  #246
Tjolley's Avatar
with lock tight..also..
Old 01-12-2013, 09:05 PM
  #247
Tjolley's Avatar
well just got the e cut out installed...
holly **** is it loud
Old 01-12-2013, 09:08 PM
  #248
574
574's Avatar
You get your fuel issue worked out??
Old 01-12-2013, 09:17 PM
  #249
Tjolley's Avatar
no...i pulled the filter its ok..
im gona start going over the ignition tomarrow...
got a huge game of beer pong tonight
Old 01-12-2013, 09:18 PM
  #250
574
574's Avatar
Lol damn sounds nice
Quick Reply: stroker lsj build
