stroker lsj build
#327
Well i pulled the plugs out and regapped to .025.
I pulled the injectors and i found some of that e85 goop that ive hurd about. Been on e for 24,540 miles this is the first time ive seen it.
Got my bore scope out and the cylinders were clean. The intake runners had a lil build up on them. I sprayed a lil of my magic cleaner on it sprayed air on it it came right off. I have a ported and polished head also.
Put it all back together and the car seems to drive better....
#336
Well I should have my pistons on Friday!!
I still need
AARP rod bolt
rod bearings
get it balanced and the block honed
I also still need piston rings from Total Seal
I should be ordering the rest of the parts in the next few days
I still need
AARP rod bolt
rod bearings
#344
Well at this moment stock lsj cams with my own degree.
Custom cams will come down the road after the engine is broke in and dynoed.
I think i solved my miss fire issuse..I THINK.
Im gona drive my car to work tomarrow so i can get on it hard.
