stroker lsj build
Old 01-26-2013, 10:59 AM
  #376
SlowBalt_06's Avatar
Originally Posted by mrbelvedere
there is no need for it to lock up tighter why try to fix what isent broken
cause thats Trevor lol someday he will try to reinvent the wheel too
Old 01-26-2013, 11:08 AM
  #377
Powell Race Parts's Avatar
Lol at Mr.B he is right. BTW I forgot to mention, my 245 40 18 tires on 9.5 wide wheels make the car tramline and somedays its frugly....with the hi helix its worse. So for a street driver, using a hi helix quaife is not something that you should do. I am perverted and deal with it.
We put a Quaife in a 600 whp road racing C6 Corvette with a 6 speed sequential gearbox. The car runs 4.10 gears, has a lot of downforce and the small 4.10 gears cant handle the load, so half way through each season we replace the differential gears. Twice the gears have broken before we decided to chang out the gears. New case and internals each time. EXCEPT:
Same Quaife is in the car. Since 2007...
Quaife is awesome ;anyone here ever broken one? I doubt it. AND if you did, lifetime warranty.
wow.
lol and complain about vibration with a square wheel? haha
Last edited by Powell Race Parts; 01-26-2013 at 11:08 AM. Reason: Automerged Doublepost
Old 01-26-2013, 11:15 AM
  #378
Tjolley's Avatar
That Wats expected of me at work..lol
Old 01-26-2013, 11:24 AM
  #379
Tjolley's Avatar
Come on now guys be nice.lol
Old 01-26-2013, 11:30 AM
  #380
Come on ..my trans fluid isn't gonna change itself
  #381
Tjolley's Avatar
Im takin this lsd apart cuz it was in a lnf that destroyed 3rd gear
Old 01-26-2013, 11:53 AM
  #382
I have run a Quaife that was in a trans that seized first gear on the mainshaft at Great Lakes Dragway, and the trans case had to be destroyed to get to the diff. quaife be fine.
amazing piece.
  #383
mrbelvedere's Avatar
im all for making **** better but sometimes there is no need but go for tj
GDS
Old 01-26-2013, 11:55 AM
  #384
zrated89's Avatar
^^^ Bitch i just called u homo
Old 01-26-2013, 11:56 AM
  #385
never rang ill call ya
GDS
Old 01-26-2013, 12:16 PM
  #386
Tjolley's Avatar
amazing piece.
Every thing looks perfect but i wanted to be sure...the trans only had 1500 miles on it
Old 01-26-2013, 02:01 PM
  #387
werd up foshizzile
GDS
Old 01-26-2013, 04:08 PM
  #388
armcclure's Avatar
amazing piece.
You talkin bout me??
Lol that's EXACTLY what happened to mine as well.
Did I ever send you pics of the carnage?
Since its somewhat related to what's going on here....
This is the aftermath of my destroyed Trans. Up at CED; hopped in the box, launched, hit 2nd and BOOM.
There's worse pics somewhere....
The quaffe was fine. I'm running it in a 4.45 now.
Old 01-26-2013, 07:29 PM
  #389
No it was Slvrred (Kyle) but the same strip/ same problem 'same weekend, lol, now I know there were two of you broke the same way, LSJ/LNF makes no nevermind evidently.
4.45 is the way to go. Amazing how I had to fight on the forum five years ago about that. Especially the turbo guys " you need the tall 3.86 ratio to let the turbo spool"
yup.
sure.
PS shout out to Droxity for bailing your butt with a replacement tranny!!
Last edited by Powell Race Parts; 01-26-2013 at 07:29 PM. Reason: Automerged Doublepost
Old 01-26-2013, 07:39 PM
  #390
armcclure's Avatar
Very much so!!
And yes, the 4.45 is amazing. The first time I drove it after getting the Trans swapped I about shat myself. 3rd on the 4.45 feels almost like 2nd did before. And I stayed neck and neck with a turbo redline making probably 70 more hp than me till the end of 3rd...
Old 01-27-2013, 12:45 AM
  #391
Tjolley's Avatar
Well aem fuel pump fit without any mods.
Car is still missing
Old 01-27-2013, 01:10 AM
  #392
armcclure's Avatar
do you have any hpt scans? if not take a couple and post them with your config
Old 01-27-2013, 01:19 AM
  #393
Tjolley's Avatar
Ok ill do that...
Old 01-29-2013, 03:43 PM
  #394
Tjolley's Avatar
Ok well havent loged the car yet been busy..
Gona switch coil with a fellow css guy close by..
He should just trade since his never gets reved over 3k anymore..lol jk slobalt
Old 01-30-2013, 10:15 PM
  #395
Tjolley's Avatar
My clevite rod bearings showed up today. Just waiting on the arp rod bolts and total seal rings....come on summit..lol
Also i set the valve cover on the head with the 1/2 studs in to make sure they cleared cuz arp only had studs that were 1" longer or 1" shorter so i went with the longer ones and i have some harded spaces for this situation so no issues they will also spread the load out on through head even more.
Old 01-30-2013, 10:21 PM
  #396
c130aviator's Avatar
Pics or its a lie
Old 01-30-2013, 10:40 PM
  #397
Tjolley's Avatar
Wat would u like to see good sir.
Old 01-30-2013, 10:46 PM
  #398
Tjolley's Avatar
stock arp head stud and the 1/2 monster next to each other gess which one is the stock
one..lol
Old 01-30-2013, 11:05 PM
  #399
FYI to use half inch studs in an LSJ you not only have to drill the head to make them fit, and of course you have increase the stud bore in the block. I have a scrapped block here, the larger stud diameter weakens the block and ended up breaking it there, at the rear of the block....good luck/ did anyone have an issue with stock size bolts/studs? wondering.
Old 01-30-2013, 11:11 PM
  #400
Tjolley's Avatar
Quick Reply: stroker lsj build
