stroker lsj build
Old 05-11-2013, 06:01 PM
  #601
c130aviator's Avatar
Originally Posted by Tjolley
Ya i have a zzp brfs
And a aem 340lph fuel pump. (works well and is only 100$ from summit racing. And theres no major mods needed. Just cut the stock fuel hose from the pump to the lid on the canister and put on the one they supplied with the pump done deal. It even plugs into the factory harness.)
really? for the lsj?
Old 05-11-2013, 06:14 PM
  #602
Tjolley's Avatar
Yep i put it in wen i was diagnosing a fueling issue a few months back. Works good..the cool thing is that summit stocks it so it only a day away for a new pump.
Old 05-11-2013, 06:16 PM
  #603
Tjolley's Avatar
Old 05-11-2013, 08:37 PM
  #604
armcclure's Avatar
How long has it been on? Always curious/worried about how different pumps holy up to E. that's why I got a deatschwerks.
Old 05-11-2013, 10:16 PM
  #605
Tjolley's Avatar
3-4 months so far.
Old 05-11-2013, 10:25 PM
  #606
Tjolley's Avatar
Look wat came today..
Old 05-11-2013, 10:28 PM
  #607
IonNinja's Avatar
3-4 months so far.
Good to know they're pretty much plug and play since I get them for cheap!
Old 05-11-2013, 10:32 PM
  #608
did you retain the stock regulator at 60 and use zzp's to go up from there to add a psi per psi of boost?
Old 05-11-2013, 10:39 PM
  #609
Tjolley's Avatar
Yes sir.
The stock system is a semi return style at the filter.
There r 2lines that come out from the tank. The larger one is the main pressure line from the pump. The smaller one goes from the filter back into the tank were the stock 60 psi fuel pressure regulator is. So if u dont plan to run under 60 psi dont bother with it.
Old 05-11-2013, 10:50 PM
  #610
armcclure's Avatar
Tuning is easier and smoother IMO if you just run full boost ref.
Old 05-11-2013, 10:57 PM
  #611
Tjolley's Avatar
It dosnt change 60 psi is 60psi
The stock regulator wont affect tuning as long as ur base pressure is 60psi or higher.
Old 05-11-2013, 11:01 PM
  #612
i am at 60 psi and idle 80 lb injectors at 800 rpm on E85. I just need the brfps to go above that so that is exactly what I am looking for. Do you have a return line from the rail?
Old 05-11-2013, 11:07 PM
  #613
Tjolley's Avatar
I plan to do that later but not right now.
I use the stock evap line for the boost referance.
It wasnt worth the hassle of running another line for a full reture style theres no gain at all. The stock system is a poor mans return style so the pump is fine. If the system was a dead head system i would do a return but this works just as well.
Old 05-11-2013, 11:13 PM
  #614
right I have read that several times, that it presurizes a line out of the fuel tank to the rail then the leftover fuel goes back in the tank from the line T'd off the regulator? Wish i had a visual I havent touched my fuel system yet.
Old 05-11-2013, 11:15 PM
  #615
Tjolley's Avatar
No
It t's at the filter mounted under the car
Old 05-11-2013, 11:17 PM
  #616
No
thanks going to go read up and dig up some google photos.
Old 05-11-2013, 11:24 PM
  #617
Tjolley's Avatar
Here im under my car. Lol
So u have 2 lines goin into the filter.
The larger one is the main line from the pump the other is the return back into the tank.
3/8 is the larger one from pump (-6)
5/16 the smaler one return to tank
Old 05-11-2013, 11:26 PM
  #618
Tjolley's Avatar
But as u turn the pressure up the flow of the pump falls off.
Old 05-11-2013, 11:28 PM
  #619
Tjolley's Avatar
And yes i know the underside of my car is dirty. It rained the other day so havent steamed of the under side yet.
Old 05-12-2013, 12:04 AM
  #620
armcclure's Avatar
Wat.
I didn't mean the settings and getting the tune set up.
I meant actually tuning it. Logs/revisions. Afr is more stable and predictable at low boost/ transitional areas like ramping into PE.
Old 05-12-2013, 12:12 AM
  #621
Wat.
i have read that but it requires a full retune (500 bucks) in my area.
Old 05-12-2013, 02:43 AM
  #622
Tjolley's Avatar
2.5+e85+ls4= :-)
Old 05-12-2013, 11:38 AM
  #623
armcclure's Avatar
Add a 445 in the mix and the tq makes you poop a little
Old 05-12-2013, 11:50 AM
  #624
Tjolley's Avatar
I already have traction issues in 3rd.
Old 05-12-2013, 01:52 PM
  #625
100% METH's Avatar
Lmao
Alan he learned how to make the fun map last night.
Quick Reply: stroker lsj build
